Help! Judder from hard acceleration after Diff&Transfer fluid change
Old Feb 23, 2024 | 11:54 PM
Poorboy325's Avatar
Angry Help! Judder from hard acceleration after Diff&Transfer fluid change
2014 RDX Base. I did a Diff & Transfer case drain/fill. followed the proper procedures. However afterwards I can feel a vibration/shudder if you hard accelerate. If you floor it its not there. If you accelerate gently its not there. Only HARD.
I've learned that although 2G RDX has no SH-AWD, it does have an intelligent AWD system that operates a clutch pack, which engages when you hard accelerate. I suspect the clutch packs are worn and require friction modifier.
MY QUESTION IS, where do I add the friction modifier and how much do I add?? I suspect the pump&clutch pack is located in the diff housing, but I want to make sure since my dumbass changed both at the same time.
Old Feb 24, 2024 | 08:21 AM
altair47's Avatar
At what mileage did this happen?
If this didn’t happen before, but after the drain/fill it started, does that mean something was done wrong?
Old Feb 24, 2024 | 02:20 PM
Poorboy325's Avatar
100k. I don't believe so. I used Honda Dual Pump fluid and followed the drain/fill till it comes out the fill bolt procedure. Car was horizontal.
Old Feb 24, 2024 | 02:45 PM
altair47's Avatar
Dual Pump fluid? Why did you put Dual Pump fluid in there?
Old Feb 24, 2024 | 02:49 PM
Poorboy325's Avatar
I've searched multiple dealer sites/forums and everyone is saying ACURA AWD FLUID DPSF (08200-9007A) is the same as HONDA DUAL PUMP FLUID (08200-9007). It's repackaged and dealers use them interchangeably. Unless I'm wrong?
For Transfer Case, I used Honda OE 75-85 gear oil.
Old Feb 24, 2024 | 02:50 PM
altair47's Avatar
I got you.
Old Feb 24, 2024 | 08:43 PM
Falconee's Avatar
Check your U joints on your drive shaft.. rumbling or juddering could easily be that especially if you feel it under your seat!
ErikDuong
3G RDX (2019+)
Oct 8, 2022 08:37 PM
ErikDuong
3G RDX Problems & Fixes
Sep 28, 2022 11:17 PM
Jgilbs06
May 29, 2021 12:05 AM
Imadreamer
Jun 18, 2019 12:09 PM
Dicorp
1G CL Problems & Fixes
Jul 29, 2007 08:04 AM
