Clutch?
Old Jul 24, 2007 | 04:24 PM
Dicorp's Avatar
Exclamation Clutch?
Just Last week i felt no clutch pedal, openened the hood, and the fluid level was low. Now the fluid is lower than before. What can this be? Slave Cylinder? The line itself?
Old Jul 24, 2007 | 04:54 PM
CLpwner's Avatar
Mmmm...
What do you mean you felt no clutch pedal?
I had a similar problem and they had to change the thing that holds the hydraulic fluid w/e ness because we have hydraulic clutches... its bad to drive it that way too... so take it to a shop asap
Old Jul 24, 2007 | 11:35 PM
Dicorp's Avatar
pedal just sinks to the floor and i couldnt change gears very well
Old Jul 25, 2007 | 07:17 AM
CLpwner's Avatar
Mmmm...
Yep... thats what happened to me aswell... take it to a shop immediately because the gears get even harder to change. I was sitting at a stop sign for about 15 seconds trying to put it in first...
Old Jul 25, 2007 | 07:43 AM
labelhunter's Avatar
It maybe your master cylinder or your slave cylinder. Look around for fluid leaking. The slave is in the front of the car on your left. I would also check at the firewall inside the car by the clutch pedal to see if the master cylinder is leaking.
Old Jul 25, 2007 | 12:36 PM
gotguinness?'s Avatar
My car does this every once in a while, what did you say it was? and how much was it to fix?
Old Jul 25, 2007 | 02:57 PM
CLpwner's Avatar
Mmmm...
I don't remember how much it was to fix I think ~100 or so...
When I had it fixed it was the master cylinder leaking fluid.
Old Jul 28, 2007 | 11:47 PM
Dicorp's Avatar
it was my slave cylinder. parts were about 30$ including fluid and maybe 15 mins of work. take offs are much better now that the clutch is disengaged properly
Old Jul 29, 2007 | 07:40 AM
CLpwner's Avatar
Mmmm...
hmm... different than mine but the same symptoms
Old Jul 29, 2007 | 08:04 AM
Dicorp's Avatar
well the two cylinders work the same way kinda so if one or the other is broken you wouldnt feel the difference.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
knight rider
Mar 4, 2016 08:59 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
