Headlights too Bright, where are the low beams?
Old Jan 25, 2026 | 08:12 AM
Jsandov1989's Avatar
3rd Gear
Hello,
2014 RDX, no fog lights. I just got the car. My headlights are too bright and people keep flashing me even though they aren't on bright. My switch only has things on the left, see attached photo, picture 1. Furthermore, it does not have the traditional low beam light indicator on the dash, that is, the green headlamp with the 3 beams facing the ground picture 2, it only has the two lights with the three beams coming out of them, picture 3.
Picture 2, Low Beam indicator that my car does not have
This is all my car has, even when HL are turned to
This is all my car has, even when HL are turned to "Auto" on the signal switch
Old Jan 25, 2026 | 10:08 AM
jimbo1763's Avatar
Are you sure you don't have brights on? They can get on accidentally if the turn signal stalk is inadvertantly pushed.
Old Jan 25, 2026 | 10:10 AM
samiam_68's Avatar
Pull the light switch lever towards you (towards the rear of the car) to turn off high beams or flash them.
Push the light switch lever away from you (towards the front of the car) to turn on high beams.
A blue high -beam indicator on the dash will light up if the high beams are on.
That picture you posted of the indicator just tells that the low beam light are on. Only when the blue indicator lights up are the high beams on.
If your lights are too bright and people are flashing, you may have:
- misaligned headlights
- too much weight in the trunk
- saggy springs in the back
- improper aftermarket lights installed
Old Jan 25, 2026 | 10:16 AM
3rd Gear
Nah, my high beams are way brighter.
Old Jan 25, 2026 | 10:17 AM
3rd Gear
I appreciate the recommendations; the lights were indeed changed because they were burnt out and nothing made them brighter, not even putting a new bulb in, so we had the dealership change the whole assembly. I've tried aligning them myself, but they just don't move.
Old Jan 25, 2026 | 10:31 AM
samiam_68's Avatar
This is how to adjust the headlights on an RDX (starts around the 2 minute mark):
zschurch
3G RDX (2019+)
Feb 7, 2023 08:47 AM
scv76
3G RLX (2013+)
14
Nov 25, 2014 04:30 PM
danmm7
Aug 26, 2009 10:05 AM
uhg0
Aug 5, 2009 04:51 PM
MANU2552
Nov 12, 2008 04:37 PM
