2014 RDX, no fog lights. I just got the car. My headlights are too bright and people keep flashing me even though they aren't on bright. My switch only has things on the left, see attached photo, picture 1. Furthermore, it does not have the traditional low beam light indicator on the dash, that is, the green headlamp with the 3 beams facing the ground picture 2, it only has the two lights with the three beams coming out of them, picture 3. Picture 2, Low Beam indicator that my car does not have
This is all my car has, even when HL are turned to "Auto" on the signal switch
Pull the light switch lever towards you (towards the rear of the car) to turn off high beams or flash them.
Push the light switch lever away from you (towards the front of the car) to turn on high beams.
A blue high -beam indicator on the dash will light up if the high beams are on.
That picture you posted of the indicator just tells that the low beam light are on. Only when the blue indicator lights up are the high beams on.
If your lights are too bright and people are flashing, you may have:
- misaligned headlights
- too much weight in the trunk
- saggy springs in the back
- improper aftermarket lights installed
I appreciate the recommendations; the lights were indeed changed because they were burnt out and nothing made them brighter, not even putting a new bulb in, so we had the dealership change the whole assembly. I've tried aligning them myself, but they just don't move.
