Driver Side window 'auto up' issue
Old Nov 24, 2015 | 11:23 AM
Acura604's Avatar
2024 RDX A SPEC
something is telling the window not to go up lol. the window WILL go up if I keep my finger on the UP switch rather than AUTO. It happens every day.
So could be the window motor.... I cant see any debris along the window to flag the 'auto up' function NOT to go up.
Old Nov 24, 2015 | 03:00 PM
Desert Ridge's Avatar
Get thee to thy dealership
Old Nov 24, 2015 | 06:53 PM
AcucaDude's Avatar
Go to the dealer! I had a similar issue last year but it wouldn't close/open at all. They'll most likely replace the motor. Seems like you have so many issues with your car already, that sucks... the windows and the front struts...
Old Nov 24, 2015 | 08:49 PM
Acura604's Avatar
2024 RDX A SPEC
^^ yah although the strut issue has been fully addressed to my satisfaction.
Just gotta deal with 2 items :
1. The window issue as above
2. Random HFL disconnects / reconnects while on the phone with someone.
Old Nov 26, 2015 | 12:43 PM
YeuEmMaiMai's Avatar
take it in, they might have to relearn the auto stop position
Old Nov 27, 2015 | 08:20 AM
ceb's Avatar
ceb
Have you done the relearn procedure? Just run the window up and down three times in a row.
If that doesn't cure it then off to the dealer.
Old Nov 27, 2015 | 08:59 AM
Shellee Trossman's Avatar
7th Gear
i agree, time for a trip to the dealer...
Old Nov 27, 2015 | 01:58 PM
not on the Acura but on the Subaru it was unplug module wait 10 minutes and re-plug and then up until window stops and then down until window stops. voilą window worked again.
I would just take it in as it is under warranty and if he continues to have problems, they are documented.
Saved my rear end when I had a coolant leak after engine overhaul that would not go away. Subaru ended up eating the entire cost of a redo on a head gasket job including machine shop costs. Turns out they STRIPPED a headbolt on reassembly and that was all she wrote. took them 22K miles of me nagging the crap out of them to get it done right.
awdacura
1/2G MDX (2001-2013)
Dec 6, 2015 08:53 PM
2Quik
Dec 3, 2015 12:28 PM
Preout
Nov 23, 2015 11:12 AM
Ilovedoughnuts
2G RDX Problems & Fixes
Nov 19, 2015 07:35 AM
polish_pat
Nov 18, 2015 09:52 AM
