Reprogram 2013 RDX key
Old 06-18-2014, 08:17 PM
4th Gear
kksacura's Avatar
Exclamation Reprogram 2013 RDX key
My driver 2 key fell down and stopped functioning. Is it possible to reprogram it.
Alternatively, I can buy another one (maybe off ebay) - Does it have to be a Driver 2 key, or can I have two driver 1 keys?
Again, is it possible to program it myself or do I need to take it to a locksmith/dealer and shell out the $100+ for it?
Thx
Karthik
Old 06-18-2014, 10:20 PM
OG
Type X's Avatar
Bring to dealer & say it stopped working, they'll replace.
If you find a good deal on a driver 1 , you can order thr backplate eith driver 2 if your anal for about 15$ from the parts area
kksacura (06-19-2014)
Old 06-19-2014, 11:29 AM
4th Gear
kksacura's Avatar
Thank you!
Could you please explain this, as I did not understand...
"If you find a good deal on a driver 1 , you can order thr backplate eith driver 2 if your anal for about 15$ from the parts area"
Old 06-19-2014, 12:05 PM
OG
Type X's Avatar
Originally Posted by kksacura
Thank you!
https://acurazine.com/forums/2g-rdx-2013-2018-404/our-keyfobs-trash-913022/
all the parts are there, if you need a complete fob its $69 at www.acuraautomotiveparts.org
Old 06-19-2014, 09:17 PM
4th Gear
kksacura's Avatar
Thank you Type X. Is this the part I need to get?
http://www.acuraautomotiveparts.org/...s=&view=normal
It says price is 79.95 and hence the confusion.
And I would need to take it in to a dealer for re=programming right? Is there no way for me to reprogram it?
Old 06-20-2014, 07:43 AM
ceb
ceb's Avatar
Received 1,276 Likes on 951 Posts
Any new key must be programmed by the dealer. You'll need to have the other key with you as well (your key 1) and be prepared to pay $150 or so for the key cutting and programming. Keys from another car (ie something bought on eBay) cannot be used.
Many dealers will do a goodwill replacement once for a damaged keyfob. Why are you reluctant to go to the dealer?
Keys are designed to withstand "normal" wear (including an occasional drop) with no damage other than cosmetic issues. If you merely "dropped" your key from a normal height (off the top of the Empire State building doesn't count) then it shouldn't have "broken".
kksacura (06-20-2014)
Old 06-20-2014, 03:01 PM
4th Gear
kksacura's Avatar
Hi ceb,
It did drop from a great height - down the elevator shaft actually.
WRT dealer, as you have mentioned, just wanted to know if there was a way around not having to spend 150 dollars.
In any case, could you please let me know if the link I had is the link to purchase a new fob?
Thank you
Karthik
Old 06-21-2014, 09:57 AM
ceb
ceb's Avatar
Hi ceb,
Thank you
Karthik
Your link goes to the ignition cylinder, not the remote fob. It'll cost you $200-$300 to replace the key - or you can spend weeks looking for something on the net that doesn't work, spend $100 on parts and THEN spend $200-$300 to get a fob that works.
Get a quote for a fob from an internet dealer (Bernardi, Curry etc) and use that to price match at your dealer.
kksacura (06-27-2014)
Old 05-10-2017, 04:53 PM
Nickfit's Avatar
I just bought a used 2014 RDX with two key fobs that say driver 1 on them. can I go to the dealer to get one off these fobs reprogrammed to driver 2? both key fobs work to unlock the vehicle using the remote button. Also, I think this is already confirmed not possible, but is there anyway to have the key fob (bought off ebay or a site (i.e. replacemyremote.com) re-programmed if it was from another vehicle?
thanks!
Old 03-18-2018, 10:51 AM
awoc's Avatar
Has anyone tried this with a 14+ MDX key?
https://youtu.be/zuCsnaUfBio
Thinking of getting a used key on ebay and trying ot.
inmydream316
05-03-2019 07:28 AM
Acura604
10-07-2015 06:08 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
vbgregg
09-11-2015 05:38 PM
Quick Reply: Reprogram 2013 RDX key
