Finally I installed the running boards. I had them sitting in my garage for quite a bit, because I wasn't able to find the right time to do it.
I couldn't imagine it was so difficult to find a car lift for rent in Houston, but eventually I found a little shop on Craiglist that charged me $60 for 4 hours.
Instructions are pretty accurate and installation is easy. Here I post some pictures just to give a better idea.
I had my brother in law helping me, and I really think he made this job much easier. We were able to finish in 2 hours.
This is the bottom left of the RDX, see the undercover you need to remove. Easy.
The right undercover
Let's start using the hole saw. The 1-1/8 inch (29mm) is the closest to the one required for installation (30mm). Worked out perfectly.
My buddy brought a Dremel, and we were able to cut the plastic like butter. It could have been done with snips or scissors.
Smoothing the edges
Final result (same for the right undercover)
The cut outs once you put the covers back in place
What's in the box?
Installing the brackets
This is the hardest part. At this point we had to lower the car and get out of the lift because the lift arms were on the way and we had no room to place the running boards.
Once we placed the first running board I noticed the black upper cover didn't look even. There were some clips not properly snapped like the one you see on the picture. We had to remove the running board, fix the clips and place the running board back. The right running board had the same issue, but that's an easy fix.
Finally I can use my torque wrench (not necessary if you have common sense, but I like to be picky like that).
Looks parallel and even, good.
Done! It was raining today and i didn't take good pictures, but I'll post some later this week as soon as I wash the car.
I really, really like the advance running boards. Don't stick much out of the body but once you open the door you can tell its a good step, especially for children. At first I was concerned they would lower the ground clearance of the car but actually the running board/floor distance is still 8 inches and change.
And that's all folks!
Reason: messed up the thread title
Only reason why I got them was for "just incase" but now that we have the sub we need to add the crossbars and make it functional. Just having the roof rails doesn't do squat!
