Advance running boards installation
Finally I installed the running boards. I had them sitting in my garage for quite a bit, because I wasn't able to find the right time to do it.
I couldn't imagine it was so difficult to find a car lift for rent in Houston, but eventually I found a little shop on Craiglist that charged me $60 for 4 hours. Instructions are pretty accurate and installation is easy. Here I post some pictures just to give a better idea. I had my brother in law helping me, and I really think he made this job much easier. We were able to finish in 2 hours. I had to buy a hole saw (DEWALT D180018IR 29mm IMPACT READY Hole Saw, 1-1/8-Inch - Core Drill Bits - Amazon.com) and I was good to go. This is the bottom left of the RDX, see the undercover you need to remove. Easy. https://cimg4.ibsrv.net/gimg/acurazi...e618da76d9.jpg The right undercover https://cimg9.ibsrv.net/gimg/acurazi...a4eb6d4ffd.jpg Let's start using the hole saw. The 1-1/8 inch (29mm) is the closest to the one required for installation (30mm). Worked out perfectly. https://cimg3.ibsrv.net/gimg/acurazi...c8ede57967.jpg https://cimg5.ibsrv.net/gimg/acurazi...dc72b3a5b3.jpg My buddy brought a Dremel, and we were able to cut the plastic like butter. It could have been done with snips or scissors. https://cimg7.ibsrv.net/gimg/acurazi...74d13a568c.jpg Smoothing the edges https://cimg5.ibsrv.net/gimg/acurazi...9328a1cef4.jpg Final result (same for the right undercover) https://cimg9.ibsrv.net/gimg/acurazi...32d59fbd8c.jpg The cut outs once you put the covers back in place https://cimg3.ibsrv.net/gimg/acurazi...a0e9c750c6.jpg https://cimg4.ibsrv.net/gimg/acurazi...1200376d3f.jpg What's in the box? https://cimg2.ibsrv.net/gimg/acurazi...7fcee4bc1b.jpg Installing the brackets https://cimg1.ibsrv.net/gimg/acurazi...38366b2dfb.jpg https://cimg3.ibsrv.net/gimg/acurazi...b3ab97b601.jpg This is the hardest part. At this point we had to lower the car and get out of the lift because the lift arms were on the way and we had no room to place the running boards. Once we placed the first running board I noticed the black upper cover didn't look even. There were some clips not properly snapped like the one you see on the picture. We had to remove the running board, fix the clips and place the running board back. The right running board had the same issue, but that's an easy fix. https://cimg5.ibsrv.net/gimg/acurazi...b1019d027e.jpg Finally I can use my torque wrench (not necessary if you have common sense, but I like to be picky like that). https://cimg9.ibsrv.net/gimg/acurazi...406f39fe84.jpg Looks parallel and even, good. https://cimg8.ibsrv.net/gimg/acurazi...14693bc6e1.jpg Done! It was raining today and i didn't take good pictures, but I'll post some later this week as soon as I wash the car. I really, really like the advance running boards. Don't stick much out of the body but once you open the door you can tell its a good step, especially for children. At first I was concerned they would lower the ground clearance of the car but actually the running board/floor distance is still 8 inches and change. https://cimg0.ibsrv.net/gimg/acurazi...e32a84ccfc.jpg https://cimg1.ibsrv.net/gimg/acurazi...a6b71379ec.jpg And that's all folks! |
Very nice DIY for the advance running boards. They look really good. In for some more pictures!
Couple of pictures after washing the car
https://cimg6.ibsrv.net/gimg/acurazi...3cfd1fbb54.jpg https://cimg8.ibsrv.net/gimg/acurazi...8236ece502.jpg |
It sticks out much less than I thought.
Just needs some roof rails to balance out the look.
Originally Posted by carbonTSEX
(Post 15545291)
Only reason why I got them was for "just incase" but now that we have the sub we need to add the crossbars and make it functional. Just having the roof rails doesn't do squat!
Thanks for posting the install. Just received the large boxes yesterday and I'll probably install the running boards on our RDX this weekend. :thumbsup:
Originally Posted by CreoUCLA
(Post 15574876)
Remember to post pictures! |
Originally Posted by giovane
(Post 15575155)
:thumbsup:
Remember to post pictures! Now if only my wife didn't hit a pole and scratch the front bumper today after I spent 4 hours detailing the RDX last weekend. :annoyed: |
(Post 15576387)
Will do. I also have the splash guards, Curt trailer hitch, and rear bumper applique to install this weekend...
(Post 15576394)
That's the reason why I wanted the Advance. Parking sensors.
https://cimg3.ibsrv.net/gimg/acurazi...3e15ca4467.jpg
Heres my white with running boards. I like the advanced package coz of the wheels. i just installed them at home on the ground. |
