2017 RDX Front Headlight Issue
Old May 6, 2021 | 08:44 PM
RDXhubby's Avatar
Noticed that the strip of light at the bottom of the assembly is not illuminating on the passenger side. Any alternatives to replacing the entire assembly? Or a way to make sure it’s not a cable or connector? Figured I’d ask around here, before dropping $1500-$2000 at the dealer for a new assembly, or trying to get a used OEM assembly in good condition (scratch-wise and tab-wise) and replacing it myself.
Passenger side (not working)
Driver’s side (working)
Old Jun 22, 2021 | 10:41 PM
Falconee's Avatar
That sucks man! Honestly live with it or try to get a used one. Car-part.com is a junkyard search engine that I have used in the past. Unfortunately i'm hoping one day that someone comes out with some way to replace the internal components on these headlights
Old Jun 23, 2021 | 03:57 AM
i mean, there is already components from used broken headlights...
one can Frankenstein if they were skilled enough... but that comes at the expense of time....
much easier just to buy a headlight from a junkyard or ebay, like you suggested
Old Jun 28, 2021 | 02:36 PM
fcostantini's Avatar
The attached schematic shows three inputs to the LED headlights (bottom of page 1).
From the diagram, it is not clear to me if pin 5 is to control the LED bar, or to send a sense signal back to the controller. I would check the connector for a bad pin or corrosion, and then compare voltages present on the left and right side headlight connectors for pins 1 to ground and pin 5 to ground. If that all checks out OK, then try replacing the light housing,
Keep us posted on what you find!
File Type: pdf
Leon Korn
3G RDX (2019+)
May 5, 2021 01:34 PM
Robert Topper
1G RDX (2007-2012)
22
Sep 22, 2018 07:36 AM
USCRx
1G RDX Problems & Fixes
Feb 1, 2017 09:28 PM
acurafans
2G RDX Photograph Gallery
Jun 6, 2015 08:42 AM
Vandelay
1G RDX (2007-2012)
Jul 31, 2013 08:11 AM
