Delete Bluetooth FM radio station
Old Aug 27, 2017 | 07:49 AM
1Nick's Avatar
Acura 2015 RDX base
I have a blue tooth Hip Hop station that will not delete, set up by previous owner. There is a local R&R station on the same FM channel. I want the R&R station.
Can not seem to be able to remove/clear the H-H station. Attempted many ways even deleted/removed previous owners phone from memory. This is a little different,, any suggestions.
Old Aug 27, 2017 | 08:08 AM
Ron A's Avatar
Administrator
Welcome to the forums.
This thread has been moved to the model specific forum for better response.
Old Aug 27, 2017 | 08:29 AM
1Nick's Avatar
Thanks Ron,
Being new to the site where is the "model specific forum," for better response.
1Nick
Old Aug 27, 2017 | 11:08 AM
Ron A's Avatar
Administrator
Originally Posted by 1Nick
Thanks Ron,
1Nick
You are in it now and the title of the forum is at the top of the page.
Old Aug 28, 2017 | 05:12 PM
Gadgetjq's Avatar
Inveterate Tinkerer
Acura 2015 RDX base
I have a blue tooth Hip Hop station that will not delete, set up by previous owner. There is a local R&R station on the same FM channel.<snip>
Nick,
FM and Bluetooth are very different frequencies and are selected by different buttons on the radio/dash so you're for sure not listening to a Bluetooth signal on your FM frequency. The only way I can think you'd end up with two music sources on the same FM channel is if you (or someone near you) use(s) one of those little FM transmitters that can send a signal from an MP3 player to a vehicle's FM frequency of the user's choosing. Those are pretty short range though so, assuming the Hip Hop follows you down the street, maybe the previous owner left something plugged in and it's hiding? Have you dug deep into the center console or anyplace there might be a power outlet?
Good luck!
msharifi
32
Dec 12, 2019 01:00 PM
gregdawg89
Jan 28, 2018 11:57 PM
Dphoffman
Sep 3, 2017 09:07 PM
janaloc
3G MDX (2014-2020)
Aug 23, 2017 05:29 AM
liftsifter
Aug 16, 2017 10:02 AM
