BT45-HON3 problem
Old Aug 15, 2017 | 10:50 AM
gregdawg89's Avatar
BT45-HON3 problem
Have just installed the USASPEC BT45-HON3 bluetooth in my 2006 TL w/ NAV and nothing works. Blank nav screen, no touch screen functionality, no radio, no CD, nothing. I installed it exactly per instructions, hooking it in to the XM unit in trunk. Anyone else have this problem? :-(
Old Aug 15, 2017 | 10:53 AM
go back over your work.
Old Aug 15, 2017 | 03:24 PM
gregdawg89's Avatar
I plan to go back and re-check my installation in the hopes that there's a bent pin or something, but frankly it's such a simple install that there's not much to go wrong. :-(
Old Dec 22, 2017 | 07:30 PM
drbobandy's Avatar
Seems to be a common theme from what I've read that some people are getting DOA units. Might try to see about a replacement. Let me know what you find out.
Old Dec 26, 2017 | 10:20 AM
mazen222's Avatar
There's 4 mini switches on the unit. check if they are properly on/off per your configuration
Old Dec 28, 2017 | 10:04 AM
RobPE's Avatar
Definitely try resetting your connections. Happened to me. Make sure you hear that satisfying click with each plug in :-).
Old Jan 22, 2018 | 10:08 PM
Focusedone's Avatar
That happen to me and i reversed the switches and it worked.
Old Jan 22, 2018 | 11:05 PM
04TTTL's Avatar
5th Gear
i would pay the $40 bucks and take it to a stereo shop...less headache
Old Jan 23, 2018 | 07:41 PM
Tidy Whitey's Avatar
Let us know if you're able to fix the problem and how you did it because I also have an 06 w/ Nav and I plan on buying the BT45 HON3 as well, so just in case I get the same problem I can fix it!
Old Jan 23, 2018 | 08:01 PM
Joecop67's Avatar
I just installed one in my 06 no navigation two weeks ago and it works fine.
Same unit is used with navi and without.
Old Jan 28, 2018 | 11:57 PM
06.UA6SD's Avatar
Make sure you read the instructions and it’ll work fine, make sure the switches are in the correct “up/down” position and I think you’re not supposed to use one of the cables that came with the kit
L1ability
4G TL Problems & Fixes
Nov 1, 2016 09:08 AM
Aleax
Oct 29, 2016 03:39 PM
Polandfreshness
Oct 23, 2016 06:15 PM
User 12221
Oct 18, 2016 05:23 PM
User 12221
Oct 14, 2016 12:21 AM
