2017 RDX Just Purchased Looking for Nav Update Guidance
Just purchased a 2017 RDX. Been searching the web for Nav update information and this is what I have gleaned from my search:
The only place to "purchase" an upgrade disc is, https://acuranavi.navigation.com/.
My questions are as follows:
How often are maps updated. If my vehicle's maps are 4 years old, will I see any significant return on my investment?
The maps are contained on a DVD. I Googled map updates and saw YouTube videos where Acura owners were using a DVD reader located in the trunk. I could not find an external DVD player in my vehicle so the only way to install in the CD player. Is that a correct assumption?
For those that I completed the update, How long did I take and what issues did you encounter?
Thanking you in advance for taking the time to respond.
Touring
You're correct on the source for the update unless you can find it on eBay or something. Since you're updating 4 years' worth, you might see some advantage. I've updated my '16 every year - the updates seem to come out annually. From year to year, I haven't seen anything significant, but I haven't done a detailed check. I just like to keep the vehicle current. The first update I did also did a significant update to the navigation software. Your '17 may already have that. If not, you'll get it when you do the new update. The updates come on two DVDs. That's a DVD player in your dash, not a CD player.
I had a hell of a time with the first update - it took about 4 hours. The following ones have taken around an hour. They recommend you run the vehicle while you're doing the update to keep the battery charged. That's a bit idiotic. I put an 8 amp charger on it with the vehicle in the second "accessory" mode, which handled the load just fine. After you install the update, it will slowly decompress itself in the vehicle to finalize the process. There's an indicator on the NAV display of that status. It took 8 hours on my RDX to finish.
Touring
Those numbers are Greek to me. Here is the info I obtained from my system:
Database Ver.ST004.03.00X
Software Ver.200.2805
So comparing your numbers to mine, it APPEARS my system is really out of date. Would you agree?
Touring
Yes. I'm guessing it's the software it was delivered with.
Touring
Having said all this, the best navigation I've found is Google Maps on my phone. The only reason I keep the NAV up to date is to keep the vehicle current. It's sometimes handy in town on 1/8 or 1/20 to check a turn coming up or to keep track of the big picture on long trips. The Wife's new Civic has Android Auto (don't get me started), although we haven't done much with it. It's a 2-door. The RDX goes on the road trips.
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Hey Guys, I'm about to update (hopefully) the nav system on a recently purchased 2018 RDX. I've received the disks. The instructions which came with the discs state, "Insert the map update DISC 1 (Application Update) into the system's disc slot (Do NOT use the DVD player slot)." Like the gentlemen who started this thread, I cannot find a separate nav system unit. So, am I correct in assuming that I use the DVD slot on the dash despite the quoted instruction? Thx!
Touring
alexmed2002
Touring
The 2nd generation RDX's have a different entertainment system that has a DVD slot in that location.
I'm pretty sure the instructions cover many models. The Acura MDX, Honda Odyssey & Pilot have rear entertainment systems with separate DVD player slots.
The slot above the center touch screen (RDX models after 2016) is for CDs and the navigation software updates. It can probably read a DVD (the format of the maps update)
but the display can't play one.
alexmed2002
Touring
alexmed2002
The instructions are specific to the 2G RDX in a booklet that's pretty complete. One thing you need to have is the authorization code that's on the packing slip. Read through what people have written up here. If you leave the engine running for the duration like they instruct, you're going to be idling for an awfully long time.
Touring
I just updated my 2017 in October. I'm not sure why you had to let your car idle for 3 hours. The installation of the update from the DVDs took about 45 minutes, that is when you need to idle your RDX. Afterwards the maps will update as you drive. That part will take about 3-4 hours. It took mine about a week and a half for mine to finally complete the map update. Not much driving during this pandemic.
Honestly - I wouldn't bother. When I owned my MDX, I updated my nav in 2010. Guess what - it still didn't include new roads that had been in place in my area for over 5 years! It's only worth it if you don't own a smart phone. And there are plenty of low cost plans that still support older phones (I's still using a an iPhone 6s), that works with Waze or Google maps just fine. Good luck on your choice.
alexmed2002
I purchased the 2017 Acura RDX knowing the navigation system is 2015 technology. Honestly, I got sick of using my phone for navigation especially when I have to make calls or send emails (voice to text works very well). I carried two phones during a previous job. Not doing that again. And I didn't want to spend more $$$ for a newer vehicle that may have Android Auto. I'll probably wait a few years for another update.
Touring
Just a note on whether the updates are worthwhile or not - I've noticed the same thing in the fact that they're way behind the real world. I've done it just to keep things current. I use a smartphone most of the time. However, if you have a 2016 RDX, the 2017 map update did more than just update the database. There was an update to the navigation software itself that was a noticeable improvement in functionality. Unfortunately, it's still slow as hell. Acura should have opted for more processor than they thought they needed or put Android Auto in.
That's correct. I've got an 8 amp charger. By turning everything off that I could find (AC, fans, lights, etc.) in accessory-2 mode (the mode where everything is "hot" but the engine isn't running), the car drew about 5 amps. The charger kept the battery topped up the whole time.
alexmed2002
Touring
Wow, great response, thank you. I have a 2018 model (late 2017 actually) that I am going to update to the 2020 maps. I hope pushing the radio butten will satisfy the radio code as there is no radio code with the car and given I am in Mexico there is no possibility of getting it.
https://radio-navicode.acura.com/
You'll need the VIN and the device serial number. From memory, I don't remember how you get the device serial number. It's on one of the screens in "Settings".
wsw (03-19-2021)
When you order the map updates, you will need the database version, Device number and VIN number. They give you directions to find this information. https://acuranavi.navigation.com/pro...fromModel=true
As I mentioned earlier, the initial installation of the navigation system update and database takes about 45 minutes. After this, the map database will continue to update AS YOU DRIVE. There is no need to let the car idle for another 3 hours, unless you want. The navigation system does move faster but like someone mentioned above, you need more processor speed to make this system as fast as we are all used to on our phones.
I likely won't update the navigation system again.
wsw (03-19-2021)
Touring
Not sure of your question. The DVD drive is the slot above the radio display head to the right of the volume knob. The DVD itself is something you purchase. They come as a 2 DVD set. The installation process transfers the data on the DVDs to the hard drive.
This^^^
The current system does not have as dedicated drive or keep a disk in place.
By the way, the hard drive also keeps a copy of the cds you play. You only have put them in once.
When I did the first update in 2017, there was a lot of debate at the dealer about the radio code. They claimed the 2G RDX didn't have one. It took a while to convince them it did. They had to call the factory to get themselves straightened out. Something had gone wrong with that first update where the system asked for it rather than accepting the button push. That update took 4 hours - on a 102° day in Wichita. It would be handy to have that information before you start the update just in case. You can get the radio code here:
This information is needed to order nav update software and as a bonus it will help you get the nav and radio codes if you don't have the original ID code stickers, which I didn't have. FINDING YOUR SYSTEM INFORMATION
To complete purchase of this map update, you will need your Database Version, Device Number and VIN.
You will be able to locate all of these numbers from a single location. Please follow the steps outlined below.
- Turn on ignition and allow navigation system to complete the start-up sequence
- Press the SETTINGS button
- Press SYSTEM SETTINGS on the navigation screen
- Press OTHER on the navigation screen
- Press SYSTEM/DEVICE INFORMATION on the navigation screen
- The following information appears. You can print a copy of this page and record the values here:
Database version __ __ __ __ __ . __ __ . __ __ (enter periods, case-sensitive)
Device number __ __ __ __ __ __ __ __ __ __ __ (11 digits, not case-sensitive, NO Dashes/Hyphens)
VIN __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ (17 digits, not case-sensitive)
Use the Device number returned from System information as the serial number for nav and radio unit to retrieve the codes at myacura.com.
dbarnhart
05-16-2017 11:27 PM
