Remote Activate Seat Heaters
Old Dec 13, 2019 | 08:45 PM
DUCRDX's Avatar
Strike Hold
Is there any way to turn on the seat heaters remotely? 2017 Advance. I leave the seat heaters on when I shut the car off. But when I remote start the car in the morning, seats are cold and off. It's been about 30 F in the mornings. I don't think it's a possibility, but figured I'd ask. Thanks
Old Dec 13, 2019 | 09:00 PM
Jfkmk's Avatar
Mine come on when I start it remotely.
Old Jan 5, 2020 | 11:43 AM
DUCRDX's Avatar
Strike Hold
What procedure are you using to get the seat heaters to come on when you auto-start the RDX with the remote fob?
What model year RDX do you have?
I've tried turning the seat heaters on prior to shutting the car off multiple times. Even at below 30f, it will not come on when I use the fob to remote start the car.
Old Jan 6, 2020 | 09:44 AM
jcross1231's Avatar
Touring
On my '16 Advance, in addition to activating the switch, there also needs to be weight in the seat for the heaters to come on.
Old Jan 7, 2020 | 09:18 PM
DUCRDX's Avatar
Strike Hold
I tested what you said Jcross. On my short 5 minute drive to work, I put both seat heaters on. While mine got nice and toasty, the passenger seat remained cold to light touch. But it did warm up when I pressed into it. I'll have to try it out on a longer drive to see if it ever comes on fully without someone sitting on it.
Old Jan 15, 2020 | 08:55 PM
DUCRDX's Avatar
Strike Hold
Jfkmk, you haven't clarified how you are able to activate the seat heaters with your remote start. I'm asking about the factory remote start.
I've trialed putting different items on the seats, up to about 5lbs so far. Still no activation of the seat heaters when I use the key fob to remote start. I"m thinking this is not possible on this model year.
Old Jan 16, 2020 | 06:41 AM
Jfkmk's Avatar
Ducrdx, sorry for the delayed response. I’ve only used the key fob remote start so far, not the phone app. Both seat heaters have been on when I get in the car, even if they were off when I parked it.
Old Jan 16, 2020 | 10:32 PM
DUCRDX's Avatar
Strike Hold
Thanks for the reply Jfkmk. I'm not sure why yours works, but mine doesn't then.
Old Jan 19, 2020 | 12:15 AM
egads's Avatar
Actually not much is clarified. For one thing, the actual model & year needs to be posted. Also whether the remote start is an Acura accessory or an aftermarket unit.
How everything works could depend entirely on that. Do any of you have a manual for the remote start?
Here is the instruction manual:
https://acura.bernardiparts.com/Imag...r_BII51241.pdf
I would look for the sticker that is supposed to be attached on the inside of the hood for actual Acura remote start accessories. It's possible that having the heated seats come on
is not something some versions do.
Old Jan 19, 2020 | 02:36 AM
Midnight Mystery's Avatar
Null and proud of it
Really... The seat heating elements are activated through weight detection?
Old Jan 22, 2020 | 04:09 PM
jcross1231's Avatar
Touring
They're activated by having the seat heat switch on and weight in the seat. It's probably to keep the seat from overheating.
RDXguy
3G RDX (2019+)
Jan 15, 2019 10:12 PM
JonfromCB
5G TLX Problems & Fixes
31
Dec 9, 2016 03:53 PM
JonfromCB
Dec 9, 2016 03:50 PM
Fool
Apr 4, 2014 07:58 AM
beerknurd
Jan 23, 2003 06:15 PM
