remote heated seat starter
Old Jan 22, 2003 | 04:25 PM
beerknurd's Avatar
Busy Living
think it would be possible to be able to hit a button on your remote and turn the seat heaters on?
The lights turn on, so why can't the seat warmers?
It would be much cheaper then remote engine start.
Old Jan 22, 2003 | 04:30 PM
louisn's Avatar
I imagine your battery would not be up to that task for more than a few minutes.
Old Jan 22, 2003 | 04:37 PM
runis's Avatar
A-CL Zen Buddha Master
louisn is right. Those seats suck up a lot of current. Unless your car was running, your batters would go dead FAST. Infact, even in the manual it says not to use the seat heaters on a regular basis as it is hard on the battery.
Old Jan 22, 2003 | 05:43 PM
soopa's Avatar
The Creator
yep... your not even supposed to run your heaters on HIGH when the car is idling because of the power drain. RTFM
just get a remote starter
Old Jan 22, 2003 | 06:00 PM
darrinb's Avatar
///M POWER
damn i didnt know that, i never turn mine off, even in the sumer i use the sometimes.
is it alright if i never have turned mine off??
Old Jan 22, 2003 | 06:31 PM
Syncros-CL6's Avatar
the new 6 speed only has the high setting, so that statement's prob not true about idling
Old Jan 22, 2003 | 06:53 PM
Shawn S's Avatar
I don’t remember reading anything about THAT.
My drivers seat heater is pretty much ON from November until I turn it OFF the first warm day in March or April.
Shawn S
Old Jan 22, 2003 | 06:56 PM
Shawn S's Avatar
The single position switch in the 6-Speed is kind of a “combo” switch.
From what I’ve experienced it comes on in the HIGH position until it hits a preset temperature.
After that it kicks to LOW and then cycles ON/OFF to maintain a comfortable range.
I remember on my 2001 if I kept the switch on HIGH it would burn my ASS if I didn’t switch it to LOW once it got warm.
So they kind of combined the functionality of the two-way switch into a single setting.
Shawn S
Old Jan 22, 2003 | 08:15 PM
FTM-1's Avatar
The same info about the seat heater use is my owners manual on my 2000TL. It says not to use them when car is sitting at idling because of the curent draw from the battery. It could casue a dead battery this is not the exact word but its about the same.
Old Jan 22, 2003 | 08:24 PM
Tom2's Avatar
Unregistered Member
Originally posted by darrinb
....i never turn mine off, even in the sumer i use the sometimes. ....
Ewwww...... Can you say "sweaty balls"?
Old Jan 22, 2003 | 08:25 PM
Tom2's Avatar
Unregistered Member
Shawn S
Hey, if you kill your battery, who cares?
Just let it roll a bit, put it in gear, turn the key on, and pop the clutch!
You don't need no stinkin' battery.
Old Jan 22, 2003 | 09:50 PM
bent09's Avatar
horny =
Quick quesiton.... Are you losing any horsepower running the seats? Because every single run at the track I have had them on.
Old Jan 22, 2003 | 09:51 PM
mc222's Avatar
I hate the Mets
So if I was a profiler - and I give you two words like summer and hot - you think about "balls" hmmmmmm???
.......Completely kidding man
Old Jan 23, 2003 | 12:34 AM
runis's Avatar
Yes
Technicall yes. The more current you are drawing from the alternator, the more mechanical resistance it will feel. That means your engine will lose more power to turn the alternator than normal. For best 0-60 & 1/4mi times I would turn off ALL non essential electrical devices including, amps, seat heaters, headlights, etc. Some would probably argue this extra loss is negligible but hey....every little bit helps. I would be curious to see dyno results with the seat heaters on HI vs. off....anyone?
Old Jan 23, 2003 | 12:45 AM
NOVAwhiteTypeS's Avatar
hmm didn't know that soopa.. in the morning I warm the car by setting the temp to high, and hit 90 degrees and auto. I've been doing that since winter of 00
Old Jan 23, 2003 | 04:46 PM
joeandcarol2's Avatar
CL 6 speeder
Yes you are. The drag from the alternator is directly proportional to the amount of current it needs to generate. Now to be honest I dont have any idea of how much of a difference there is, but yes running those heaters increases drag.
Old Jan 23, 2003 | 06:15 PM
1killercls's Avatar
GEEZER
Toasty Warm
Only used mine (Heated Seats) once so far..? Oh yea...I live in Florida.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
