Rear O2 Sensor Replacement
Old Jun 14, 2021 | 06:43 PM
emry's Avatar
I am about to replace both front and rear O2 sensors on my 2015 RDX base. Unlike the rear one, the front one is pretty straight forward.
Do I have to remove any reel or parts to have a better access? Also where is the connecting harness located for the rear sensor?
Old Jun 23, 2021 | 12:28 PM
hongthan's Avatar
I can not answer your question since we only got 22k miles on our 2017. Just curious what make you to change the O2 sensors? Did you get error code for it?
Old Jun 23, 2021 | 06:47 PM
doesnt look like you have a strut bar going across the engine bay, so you dont have to remove that...it looks like it's a tight squeeze of your hands tho
Old Jun 29, 2021 | 03:03 PM
jjrphs's Avatar
Reason for replacing both O2 sensors? CEL? Reason I ask is since your "prophylactically" replacing your coil packs...I thought this might be the case here as well.
Old Jun 29, 2021 | 04:56 PM
^good catch
Old Aug 7, 2021 | 12:53 PM
emry's Avatar
Yes the same reason. It makes sense to replace the O2 sensors as preventive maintenance at around 100K miles. Or alternatively you can wait until in the middle of nowhere they give up and strand you with huge cost of towing and repair. I do not wait for catching the disease then go to the doctors for cure. I do vaccination.
Old Sep 8, 2021 | 07:30 PM
jjrphs's Avatar
You've actually had a bad O2 sensor strand you on the side of the road?
Old Sep 12, 2021 | 09:37 PM
egads's Avatar
I think medication for OCD might be a better use of funds. I have never had to replace any of this stuff on any Honda. A couple well into 200k and one over 300k.
Now if one gets to 150k or so without Muzzling the VCM on one of the V6s so equipped, and there has been malfunctions caused by that, it can affect the CAT.
Old Sep 13, 2021 | 05:53 AM
Kelsen's Avatar
For what it's worth, I had to replace an O2 sensor on my 03 Accord (4-cylinder), and it was within the first 100K miles. But that's the only time, out of an awful lot of Honda miles on quite a few vehicles.
RFT!!!
Dave Kelsen
"People do not seem to realize that their opinion of the world is also a confession of character." -- Ralph Waldo Emerson
Old Sep 13, 2021 | 11:34 AM
jjrphs's Avatar
Did the bad O2 sensor leave you stranded you on the side of the road?
Old Sep 13, 2021 | 01:21 PM
Do you replace your cats every 10 years too?. you know, just in case?
sounds like you like throwing money away at things unnecessarily
Old Sep 13, 2021 | 09:06 PM
Kelsen's Avatar
It did not. I did have to buy a 'special' tool, and take my passenger seat out, though.
RFT!!!
Dave Kelsen
Throwing acid is wrong, in some people's eyes.
Old Sep 13, 2021 | 09:38 PM
emry's Avatar
Would have been better to spend it on a medical specialist. Fact not an opinion.
Old Sep 13, 2021 | 10:15 PM
Kelsen's Avatar
Don't try to bandy words with your betters -- and that's pretty much anyone with a pulse. You're not smart enough to know about O2 sensors, much less proper use of the English language. It's not really your fault you're stupid, but you will bear the brunt of it nonetheless. Your best bet is to say as little as possible, letting the fewest number of people glean the obvious.
RFT!!!
Dave Kelsen
"It is a sad thing when men have neither the wit to speak well nor the judgment to hold their tongues." - Jean de la Bruyere
Last edited by Kelsen; Sep 13, 2021 at 10:21 PM. Reason: Don't try to teach a pig to sing.
Old Sep 14, 2021 | 06:21 PM
emry's Avatar
Obviously you know much more about them to take the front seat off to replace them
Amazing how the admin let trolls like you and that million mile planetary guy stick around this forum with foul language. Anyway, your usage of language shows about your stupidity. Not worth of my time.
It is a sad thing when men have neither the wit to hold their tongues
Old Sep 14, 2021 | 06:55 PM
altair47's Avatar
That's right, he also needs to change the fuel pump, make a complete rebuild of the transmission. In general, it is best to change the gasket between the steering wheel and the driver's seat and forget about the problems
Adoniram
Dec 17, 2016 05:26 PM
gleetrevino
Jul 11, 2013 08:59 PM
9632tl
1G TL (1996-1998)
Apr 6, 2011 12:10 AM
acurakev
Jul 19, 2004 10:58 AM
