Propeller Shaft Replaced
Old 04-18-2014, 02:49 PM
thephantom's Avatar
I brought my RDX in to the dealer today for an A-1 service (I had a $25 off coupon) and had my propeller shaft replaced at the same time. Even though my RDX didn't shake or vibrate excessively, the new shaft definitely made the ride much smoother!
Old 04-18-2014, 02:51 PM
mrgold35
mrgold35's Avatar
Received 1,510 Likes on 1,178 Posts
Was it part of a TSB? Acura usually doesn't do routine checks on a "A" service, usually "B" service.
Old 04-18-2014, 02:54 PM
thephantom's Avatar
It is a part of a TSB. I asked for it when I made my appointment. The part number is: 40100-TX4-A02
Old 04-18-2014, 04:23 PM
kareshi's Avatar
Do you have the TSB # handy?
Old 04-18-2014, 06:48 PM
CoachRick's Avatar
Propeller shaft? Is that the new amphib package for Acura?
Old 04-18-2014, 06:52 PM
mrgold35
mrgold35's Avatar
Found a pdf about the TSB:
https://dl.dropboxusercontent.com/u/...ra/B14-001.pdf
Old 04-19-2014, 01:07 AM
Summer is Coming
Rocket_man's Avatar
So I'm confused.... the TSB seems to be about vibration during VCM... but this is only for the AWD version. So is it that only AWD versions have vibration during VCM?
Old 04-19-2014, 11:26 AM
hand-filer's Avatar
They revised the rubber isolator of the center support bearing of the propeller shaft. This component is attached to the floor pan and was the cause of the vibration.
I suspect that when in VCM mode the additional vibration was transferred through this part.
All I know is that since having the propeller shaft replaced I can no longer feel any vibration.
I'm assuming that FWD vehicles don't have this issue.
marcelft
07-10-2018 06:17 PM
justin7779
12-25-2015 10:33 PM
niray9
12-08-2015 07:34 PM
Frathora
09-28-2015 11:29 PM
04tler
09-10-2015 01:13 PM
Quick Reply: Propeller Shaft Replaced
