Oil Consumption
Old Mar 28, 2013 | 10:59 PM
Kapadiab's Avatar
Oil Consumption
Oil level is low end mark @ 6900 miles and oil change is @ 70%. Is this normal with total car miles 6900?
Old Mar 29, 2013 | 04:07 AM
Domm's Avatar
Are you sure it was filled to the max to begin with? It could be slightly underfilled, which could result in the oil being so low. It is expected to have slight oil consumption on a new vehicle.
Old Mar 29, 2013 | 06:00 AM
Dorsey's Avatar
Two thoughts. How long did you wait after shutting it off to check the oil? It can take quite a bit of time for the oil to drain down from the valve train. Also, is it on a level surface as that can also give a false reading. 70% oil life left seems like alot at 6900 miles. Mine was at 15% at around 6300. Sounds like your miles are mostly highway.
Old Mar 29, 2013 | 09:06 PM
Kapadiab's Avatar
I did not check the oil level when I purchased it. Sorry I was not clear, 30% left on the indicator. I will add some oil, until time to replace oil.
Old Mar 29, 2013 | 09:09 PM
Domm's Avatar
Originally Posted by Kapadiab
I did not check the oil level when I purchased it. Sorry I was not clear, 30% left on the indicator. in will add some oil, until time to replace oil.
When I performed my first oil change on the RDX, it was down almost 2 quarts of oil. I assumed it was due to the engine breaking in. No oil burn on the second oil change.
Old Mar 29, 2013 | 09:24 PM
Kapadiab's Avatar
Thank Domm
Old Mar 30, 2013 | 03:55 PM
Mikey Dallas's Avatar
On this topic. I have had my RDX for 10 months now and have about 6K on it. Oil life is at 30%. Any thoughts on if I should have it changed by one year regardless of the oil life level?
Old Mar 30, 2013 | 04:02 PM
Domm's Avatar
Originally Posted by Mikey Dallas
On this topic. I have had my RDX for 10 months now and have about 6Kon it. Oil life is at 30%. Any thoughts on if I should have it changed by one year regardless of the oil life level?
Most Acura owners would suggest going by the oil life indicator. It'll go off at 10-15% according to my service advisor.
Old Mar 30, 2013 | 04:50 PM
bh9712's Avatar
I will hit the one year mark in a few days. I only have 4900 miles on mine, oil life was at 40% and I took it in this week. The owner's manual calls for changing it at one year even if the Service message doesn't appear. I'd worry about Acura not honoring the warranty if I didn't follow the manual.
I have two years free service, so that made it an easier decision for me.
At your current pace, your oil life will be down to about 15% by the time you hit a year, which may make your decision easier...
Old Mar 30, 2013 | 05:30 PM
CoachRick's Avatar
I'd get it changed for the ?expected? hot weather. If you're in the northern climes, you could wait a bit; but we've already seen 90 in central Texas and summer should hit in about 2 weeks. I'd like the fresh stuff to be helping protect the engine when the ambient temps top 100F(starting in May around here)
IBankMouse
Jun 13, 2020 12:53 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Thuneau
Oct 3, 2015 04:19 PM
jubikej
1G RDX Problems & Fixes
Sep 30, 2015 01:13 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
