J35Z2 Differences
Old 03-29-2024, 01:00 PM
6th Gear
AgentLongwood's Avatar
J35Z2 Differences
I noticed that the '13-'18 Acura RDX uses a J35Z2 as it's V6. The J35Z2 is the same engine listed in the '08-'12 Accord V6 . What I can't find is what are the specific differences between the Accord and RDX versions of the J35Z2? The only info I can find is on the wiki, which shows they have the same compression (10.5:1), same redline (6900), and same RPMs for peak power(6200) and peak torque (6200).
Since all that is identical, why do the engines have different octane requirements? And why does the Acura one make 3 ft-lbs LESS torque at the same peak RPM, and 10 hp MORE at the same peak RPM?
What are the differences between the motors? Is it just software? Like VTEC engagement, or cam timing? Does anyone have an actual answer for certain, or is it all just our best guesses?
Old 03-29-2024, 01:35 PM
alexmed2002
Alex Medeiros's Avatar
The Acura is tuned for premium which in turn gets a little bit better output. If you use anything lower than premium however, the car will have to retard its timing and will not run as good as on premium. The Honda is tuned for regular octane gas, so it ultimately looses some performance versus the Acura and gains nothing by using higher octanes. My opinion is that in order to differentiate the Acura apart from the Honda, they wanted to make it a little more powerful and by needing premium gas, it makes the car sound more expensive and luxurious versus the very bland Honda.
Old 03-29-2024, 01:45 PM
6th Gear
RIght on, I kinda figured the tuning could be different. That was my guess, anyway. Does anybody know what the actual tuning differences are? Cam timing, ignition timing, fueling, vtec engagement? Do they use different cams, even? Does anybody know what the actual differences are? Or are we just guessing about tuning and don't have a way to get actual answers?
Old 03-29-2024, 07:38 PM
altair47's Avatar
20132015 RDX is the same engine as the 2008–2012 Accord, 20162018 RDX is a very different engine, but with the same name.
It is more powerful because the ignition is designed for premium gasoline.
Kelsen (03-30-2024)
Old 03-31-2024, 12:56 AM
6th Gear
If it's "Very Different" then what are the actual differences? Specifically
Old 03-31-2024, 06:37 AM
altair47's Avatar
As far as I know, on the new J35Z2 at least the short block is molded for 2 knock sensors, VTEC and everything related to valve opening has received a new design
Kelsen (04-01-2024)
Old 04-15-2024, 01:54 PM
6th Gear
This is awesome. Thank you for replying with actual specifics and photos. That's genuinely helpful. Appreciate it.
altair47 (04-15-2024)
Old 04-17-2024, 10:13 PM
7th Gear
thericepatch's Avatar
There are a number of differences between the two motors, including the different knock sensors, different sensors on the vcm, and the RDX has plastic valve covers. The casting is different for the heads,cams, as well as the block. RDX is 5GO castings, the other models are R70 castings. The oil filter housing and gaskets is different as well. They are somewhat interchangeable as an assembly, I've used the RDX engine in an 09 Pilot and 08 Odyssey. The RDX engine is extremely cheap ($500). Took some modifications but runs great. They do have a constant check engine light due to a vps (valve pause system) code that I have never resolved, so it's not a perfect swap at this point. I did put together a youtube video on it when I did the swaps 2 years ago
I'd love to have some collaboration to get this combination working without error codes.
kaehlin (04-18-2024)
Old 04-18-2024, 07:08 AM
altair47's Avatar
Originally Posted by thericepatch
There are a number of differences between the two motors, including the different knock sensors, different sensors on the vcm, and the RDX has plastic valve covers. The casting is different for the heads,cams, as well as the block. RDX is 5GO castings, the other models are R70 castings. The oil filter housing and gaskets is different as well. They are somewhat interchangeable as an assembly, I've used the RDX engine in an 09 Pilot and 08 Odyssey. The RDX engine is extremely cheap ($500). Took some modifications but runs great. They do have a constant check engine light due to a vps (valve pause system) code that I have never resolved, so it's not a perfect swap at this point. I did put together a youtube video on it when I did the swaps 2 years ago https://youtu.be/eFJC0imStrI?si=wcf48Yw2jLc9jfu_ I'd love to have some collaboration to get this combination working without error codes.
This guy is very funny, instead of changing the engine from 2013-2015 RDX, he did all this job and now his CEL will be on. But he saved $500!
Old 04-18-2024, 07:48 AM
7th Gear
YOLO, a little experimenting is fun and builds knowledge. The motor was only $500 with 50k miles on it, so it saved me over $1000 per motor. Basically I paid the cost of one head and got a full low mileage motor that runs great in a couple of 15 year old vehicles. But hey, if you are more worried about a cel than than saving a couple thousand, to each his own.
Old 04-18-2024, 08:10 PM
altair47's Avatar
It all depends on how much your labor costs; if you work for food, then this is a profitable occupation, but if an hour of your labor costs at least $50, then it is a fiasco.
Old 04-18-2024, 08:25 PM
7th Gear
$500? Can you provide a link where you can buy such an engine for $500? It all depends on how much your labor costs; if you work for food, then this is a profitable occupation, but if an hour of your labor costs at least $50, then it is a fiasco.
Sure, check eBay. https://www.ebay.com/itm/29634032453...mis&media=COPY
This particular listing has unknown miles, but it's on a 5-7 yo motor and includes shipping. Lkq sells them all the time, I drove a couple hours and saved shipping on one of mine, I think I got it for less than $500. Again, my swaps were 2 years ago, but this is still a current price. With shipping. I'm not saying this is the Holy Grail of motor swaps, but getting a low mileage 5-7yo 3.5 to drop in your ride for $500 is a dang sweet deal for some of us budget conscious types.
altair47 (04-18-2024)
Old 04-18-2024, 08:40 PM
altair47's Avatar
What DTC do you have?
Old 04-18-2024, 09:33 PM
7th Gear
P3497 vps deactivated bank 2.
Old 04-18-2024, 09:58 PM
altair47's Avatar
Only one code? It's not bad at all. Have you transferred all the VСM presure sensors and the resistance of the solenoids is the same as the original Odyssey ones?
Old 04-18-2024, 10:01 PM
7th Gear
We had to change the sensors due to different plugs. I don't think we tested resistance at the solenoids.
Old 04-18-2024, 10:15 PM
altair47's Avatar
Do you have a VCM muzzler?
Old 04-18-2024, 10:19 PM
7th Gear
We ran the resistor mod, as we have done on hundreds of these motors. I think we ran 120 ohm resistor on those two.
Old 04-18-2024, 10:27 PM
altair47's Avatar
Due to the fact that you don't have a code for the knock sensor, I liked the idea of installing these engines on cars with electric power steering. That is, of all the changes you will only need to programmatically remove the EGR and VCM, and this is done very easily.
Tom0613
2G RDX Performance Parts & Modifications
19
06-03-2016 08:59 AM
kevTL888
05-01-2015 11:38 PM
pmartone
04-03-2013 11:26 PM
Stump
01-15-2013 09:51 PM
provench
1G RDX (2007-2012)
01-25-2005 10:24 PM
Quick Reply: J35Z2 Differences
