Glovebox Light + Center Console Light
Old Oct 31, 2020 | 08:05 PM
Alex Medeiros's Avatar
alexmed2002
Hi all,
I had a quick question. Does anyone know where to find replacement bulbs for the glovebox light and center console light? Are they the same bulbs, and are they easy to replace? Thanks!
Old Nov 4, 2020 | 09:19 PM
Muzh's Avatar
glove box light bulb is t5, a very small bulb, and to replace it you just pull the cap holding the bulb out directly, replace and push back.
center console light, do you mean the blue ambient light? it's a whole led assembly light switch. it looks like this: search ebay for key words "HONDA Instrument Panel Dash-Courtesy Lamp 34760TA0J01, Ambient Light Foot,White". to replace it, pull the panel down with pry tools, unlink the wire, and twist to remove the whole led assembly, replace and redo the install.
door light, to replace use flat-head screw driver to remove the plastic cap, replace the bulb and put cap back. for some more fun, you can install similar: https://www.ebay.com/itm/Led-Door-Li...gAAOSw-B9edtGd
Old Nov 4, 2020 | 09:41 PM
alexmed2002
When I said center console, I was referring to inside the armrest. My bad.
Old Nov 4, 2020 | 11:29 PM
Muzh's Avatar
they are the same t5 bulb then.
Old Nov 4, 2020 | 11:30 PM
alexmed2002
Thanks for the help!
ykelsayed
Oct 9, 2024 10:16 PM
Kabayo
Jun 26, 2013 02:21 PM
H's gray 03 CL type S
Aug 4, 2010 08:37 PM
gaping46and2
Jan 30, 2008 10:38 PM
AsianDDRManiac
Aug 18, 2005 11:28 AM
