Front struts
Old Dec 3, 2021 | 12:10 PM
wallmike's Avatar
Front struts
Time for me to get the front struts replaced.
https://www.carid.com/kyb/excel-g-shock-and-strut.html
Is KYB really manufacturing front struts? I recall seeing threads where folks mentioned they have rear shocks only for the RDX.
The website says these struts fit my 2014 RDX.
Do I need to replace the entire strut assembly or just the strut and not worry about the spring?
Thanks.
Old Dec 3, 2021 | 11:51 PM
alpha2beta's Avatar
Thanks.
KYB 3340165 Front Left & KYB 3340164 Front Right
I wouldn't replace the spring unless it's broken which is unlikely, but I would replace the mount and bearings.
51726-TX4-A01 51920-TX4-A01
You need two of each. Honda/Acura only has these parts.
Old Dec 4, 2021 | 10:27 AM
Poolman's Avatar
KYB installed on my 2015 back in August. Much better than the OEM parts that came with the car,,along with the KYB rear shocks. The OEM parts were junk next to the KYB that replaced everything,,my 2 cent issued.
Old Dec 4, 2021 | 12:20 PM
Tech's Avatar
Originally Posted by Poolman
The OEM parts were junk...
How many miles were on them when you had them replaced?
Old Dec 4, 2021 | 05:24 PM
alpha2beta's Avatar
KYB is a upgrade in every way compared to the OEM shocks and Struts, better ride quality and handling. Off the lot brand new RDX front struts rattled a bit, dealership failed to repair even after many complaints, the KYBs is what Acura should have put on from the factory, yes they are that much better.
Old Dec 4, 2021 | 08:33 PM
wallmike's Avatar
I am hearing squeaking noise from the rear also. When I push down, the rear bounces a couple of times. Don't know if that means anything.
Looked for KYB shocks for the rear. Can't find them. Out of stock everywhere I looked. Does anyone know where I could find them?
Old Dec 4, 2021 | 10:21 PM
alpha2beta's Avatar
If the vehicle does anything more than goes back up and stops after pushing down on it, the shocks are shot, you need new ones.
Old Dec 5, 2021 | 03:52 PM
wallmike's Avatar
If I were to get the Front struts & Rear shocks replaced at different times (I can't find the rear shocks right now), would I need to get alignment each time separately?
Old Dec 6, 2021 | 11:23 AM
alpha2beta's Avatar
Rears are very hard to get ahold of right now, I believe you can order them from tirerack.com I believe they are shipping in January it should tell you at checkout. Alignment only needs to be checked when you do the front struts, usually the alignment stays in check. But always get it checked out after having the front done.
Old Dec 8, 2021 | 03:28 PM
Poolman's Avatar
I replaced the rear shocks at about 50k miles. Had replaced the rear shocks already because of a defective parts. After installing the KYB shocks the ride was much better. The front struts were replaced at about 90k miles and the reason that I waited that long, was that KYB hadn't gotten their production caught up so that one could purchase the new struts. Oh to add the cost of KYB struts is a fraction of the cost of OEM struts. But if you want to keep your Acura stock, you can shell out the 3 times the cost for the Acura parts
Old Dec 13, 2021 | 05:53 PM
Tech's Avatar
After installing the KYB shocks the ride was much better. The front struts were replaced at about 90k miles...
I only asked what the mileage was because on another forum I am on, many members tell me how some aftermarket component "totally transformed" their vehicle. For example, some new aftermarket control arm bushings. What they forgot to tell everybody was the original control arm bushings were 15 or more years old. Well no wonder any new control arm bushing is better...duhhh.
I put some new KYB GR-2 struts on my 1999 CR-V in 2010 at 118,171 miles thinking the OEM struts must be done after 11 years. Amazingly the original struts were marginally better than the new KYBs. I hope the KYBs are a lot better now for when I need them.
Just sayin.
Old Dec 14, 2021 | 10:58 AM
Poolman's Avatar
I understand what you saying. The front struts were around 95k miles and replacing them with anything might have made a difference, but the rear shocks ,,I had replaced them with OEM parts at 35k miles and they still were junk IMO. After replacing the rear shocks again at 40k miles with the KYB and was pleased with the ride. New front struts could or could not be a problem , because at 100k miles they should be replaced anyway. Wish there was a heavy duty rear sway bar for these rides .
Old Dec 16, 2021 | 11:06 PM
alpha2beta's Avatar
Just sayin.
As I said in my previous post that the factory struts rattled from day one brand new off the lot, two of the other new RDXs used as loner cars rattled too, they also ride stiff and allow the vehicle to roll, the KYBs ride MUCH better and have LESS roll than NEW, I had my friend drive my 2013 RDX after switching to the KYBs he also agreed, he has a 2014 RDX with half the miles. His front struts also rattle exactly like my factory struts.
Old Dec 17, 2021 | 09:49 AM
hongthan's Avatar
KYB are OEM supplier for Toyota vehicles. I just replaced the front struts in my 06 Sienna XLE with KYB whole assembly. They works well in my case. Not sure who are the oem supplier for Hondas.
Old Dec 18, 2021 | 10:16 AM
Tech's Avatar
I was comparing my KYBs for my Honda CRV which I was not impressed with. That is why I stated "I hope the KYBs are a lot better now for when I need them".
Shock absorbers do not prevent roll, they are dampers. What prevents roll are the springs and the roll bar.
BTW, no rattles in my 2017 RDX.
Old Dec 18, 2021 | 07:41 PM
alpha2beta's Avatar
To be exact what I am talking about roll, is the initial turn in has less roll, but once the turn in is complete and the vehicle settles in the turn that's the same as the OEM struts.
Plus the 2016-2018 RDX has a newer design suspension including the struts.
hovbuild
Dec 25, 2024 09:28 AM
Moofles
May 21, 2021 12:58 PM
XDR3102
2G RDX Problems & Fixes
Dec 25, 2018 09:40 PM
FreshMeat
1G RDX Tires, Wheels & Suspension
Mar 16, 2016 07:41 AM
Lanesky_OH8RDX
20
Dec 1, 2012 10:50 AM
