Ecu ?
Old Sep 7, 2025 | 03:43 PM
Poolman's Avatar
Ecu ?
Been chasing this problem for sometime now. When sitting at idle and in gear at a stop light or in line at fast food, the engine will stumble , rpm
will drop and temp gauge drop down as if the engine had been turned off. This is only for a fraction of a second and then the engine
will be running again. No codes are thrown , just the blip or momentary loss of power and just as fast it's back running again. Have replace crank sensor
along with ignition relay but no help with the problem.. Could this be a ECU going bad and if so can I use one from another rdx ?
Any ideas appreciated .
Old Sep 8, 2025 | 06:52 AM
altair47's Avatar
Because of their high reliability, these units cost in the $25 range, so it costs you almost nothing to buy one, borrow an Autel(Snap-On can't do that.) from someone and pair it with an immobilizer. Replacement and pairing takes about 10-15 minutes.
Old Sep 8, 2025 | 07:17 AM
Poolman's Avatar
Thanks altair. So I must be thinking right. When you stated, pair with an immobilizer..is that my electronic key. I'm not getting that part.
Thanks again
Old Sep 8, 2025 | 07:23 AM
altair47's Avatar
Thanks again
When you enter the Immobilizer module via the Autel scanner, there is a procedure - Replacement of the ECU (Snapon also has such a procedure, but it does not work in my two very $$$ scanners).
Old Sep 9, 2025 | 04:08 PM
Poolman's Avatar
Looking around the small town I'm in trying to find someone that make this happen with the ECU work. Might go off and pick up a piece of equipment that can
do the job. Would still be cheaper than having the dealer do the work. Thanks Again.
Old Sep 9, 2025 | 06:50 PM
altair47's Avatar
This will only work if you buy a scanner on Amazon, do the work, and then return it. Because $500 Autel is still not cheap for a one-time procedure.
Old Sep 11, 2025 | 02:17 PM
EasyLoveRDX's Avatar
How old is your battery? Have you checked that the terminal nuts & bolts are securely tightened down?
Old Sep 12, 2025 | 07:00 AM
Poolman's Avatar
Alls good with battery and alt.
BlackMax
Jul 21, 2023 09:34 PM
DunerDean
Jun 5, 2018 06:47 PM
Acura2g
Jan 3, 2010 02:27 PM
VTEC
Dec 28, 2003 02:36 AM
xerothermic
Nov 23, 2001 12:45 AM
