B12346
B12346
Code popped up this week on my 2014 RDX with 308,000+ miles.
I do not recall at what mileage the previous timing belt, spark plugs service was done. The local shop where I got it done is closed and I can't find my records for that service.
I am thinking it is not 105,000 miles ago. How does the car know when it is due? Computer in the car? I have no issues that should require new spark plugs either.
I replace the filters and they look fine to me despite getting code for it.
I checked the brake fluid and it is getting dark. but no code for it.
It has been at least two years since the last coolant flush. Again, no code for it.
Thanks.
Thanks.
Honda does not have such codes, how did you read this code?
Give me your VIN number and I'll take a look at the car history.
look here for Acura service codes https://www.motorcarsacura.com/acura-service-codes/
It looks like it's maintenance minder service codes. Some of the maintenance is based on an algorithm that monitors your driving; others are based on mileage. The one i would be concerned about is the timing chain only because you don't know when it was last done. If it was 105k miles, you are way overdue. If it was 210k miles, you may have a little time.
alexmed2002
I cannot help but ask what this might mean in English. Inquiring minds want to know!
RFT!!!
Dave Kelsen
It's true that Smokey the Bear deserves praise for his campaign against forest fires, but nobody ever mentions the boy scouts he kills for their hats.
RFT!!!
Dave Kelsen
I can explain in Russian)
Kelsen (10-26-2021)
So if you're relaying that code correctly, you are doing a full "B" service (engine oil + filter, full inspection) plus:
- Rotating tires
- Replacing your air filters
- Replacing trans fluid
- Doing the 105k service, which includes timing belt, tb tensioner, tb pulleys, replacing your water pump, (during which you should replace your coolant as well), replacing the spark plugs, and a potential valve adjustment (if needed).
- Replacing diff fluid, assuming you're AWD.
In my opinion, it looks more intimidating than it actually is. You're essentially replacing all fluids and filters, in addition to your 105k service (B4 service). To your point, you can probably pass over various things like the air filters and certain fluids depending on their condition. If a fluid or filter looks dirty, you ought to change it. The computer only uses mileage intervals to suggest when things needs to be changed, as others have said. Unfortunately it does not account for the actual state of any fluids or parts.
If you're going to do the 105k service, your coolant typically gets replaced at this time, since the water pump comes off. This would also be an optimal time to replace your thermostat (if its original) since the coolant is drained, but that's up to you.
I'd suggest an Aisin kit for the timing belt and water pump - great success across Acuras on the forums here, can save money over paying a premium for parts at the stealership. The kit includes everything you need for the service, minus spark plugs and coolant. You can get the spark plugs pretty much anywhere, and just make sure to get OEM honda type 2 coolant. https://www.rockauto.com/en/moreinfo...=16088&jsn=876
As for spark plugs, I think NGK laser iridium is the go-to brand across all models, but hopefully someone else can chime in to confirm or deny that claim.
Lastly, unless you're seeing any performance issues, a valve adjustment can be subjective. Further if you're experiencing valve noise, or maybe you want to replace the valve cover gaskets to stop an oil leak, yeah getting one at this time would be beneficial. Otherwise it's up to you. If they've gone that entire 300k+ without being adjusted, I'd maybe look into it just for fun.
Good luck!
- Rotating tires
Good luck!
Kelsen (10-26-2021)
My bad gentlemen. I was not clear. I know what these codes mean. I was just wondering how they appear despite the intervals not being correct. For example, the timing belt to be replaced at 105K or 100K despite my previous replacement was not that many miles ago.
In any case, I got estimate from the always generous and reasonable stealership for the work to be done.
Timing belt $1100
Spark plugs $525
Transmission & transfer case fluid $250
Rear differential fluid $120
Engine & Cabin filters $120 (I always do this myself for $20 parts)
I am going to do the spark plugs myself.
Timing belt $1100
Spark plugs $525
My bad gentlemen. I know what these codes mean. I was just wondering how they appear despite the intervals not being correct. For example, the timing belt to be replaced at 105K or 100K.
Timingbelt $1100
Sparkplugs
Timingbelt $1100
Sparkplugs
Timing belt $1100
Spark plugs $525
Timing belt $1100
Spark plugs $525
The algorithm does oil life, the rest is based on how many oil changes you have had. That is based on the old 7500 mile oil change interval.
So: at the fourth oil change you get codes for 30,000 mile items (filters, trans fluid)
At the 14th oil change you get stuff for the 105k service.
There is almost never a need to replace Honda coolant before the 105k service. It was even 120k when there was a mileage based service chart in the owner's manual.
But of course you would go ahead and change it with the water pump at 105k. (that said, apparently those that live in the frozen north do change theirs more often)
Using the real thing is important because it does last that long and you don't "flush" out coolant in a Honda engine. Some old fluid will remain. Best to mix the same thing in there.
Brake fluid is every three years regardless of miles.
altair47 (11-02-2021)
The following 2 users liked this post by wallmike:
Chargersix (11-12-2021),
chilly731 (11-12-2021)
I called an Acura dealer while driving through Vegas from Irvine. Asked what they charge for transmission & transfer case fluid service. $360. WTF?! I said dealer in Denver is $110 less. "This is our price" he said. F U Acura dealers. ALL of you.
This thread gives me hope. I'm never worried about the vehicle itself, or the engine, but the transmission scares the hell out of me. None of the Japanese companies know how to make a damn decent transmission.
The following 2 users liked this post by chilly731:
kaehlin (11-13-2021)
Change the fluid every 30k at least and every other oil change if you want to be prudent. (Normal 1/3 drain & fill)
I agree, this transmission is also not expensive at all and replacement(7-10hr labor) along with a good used transmission(40-80K milles) will cost about $2K, very very cheap.
Clairette the CL
2G CL Problems & Fixes
12-07-2016 10:38 PM
