B12346
Old Oct 24, 2021 | 12:51 PM
wallmike's Avatar
B12346
Code popped up this week on my 2014 RDX with 308,000+ miles.
I do not recall at what mileage the previous timing belt, spark plugs service was done. The local shop where I got it done is closed and I can't find my records for that service.
I am thinking it is not 105,000 miles ago. How does the car know when it is due? Computer in the car? I have no issues that should require new spark plugs either.
I replace the filters and they look fine to me despite getting code for it.
I checked the brake fluid and it is getting dark. but no code for it.
It has been at least two years since the last coolant flush. Again, no code for it.
Thanks.
Old Oct 24, 2021 | 08:10 PM
altair47's Avatar
Honda does not have such codes, how did you read this code?
Give me your VIN number and I'll take a look at the car history.
Old Oct 25, 2021 | 11:09 AM
computerperson's Avatar
look here for Acura service codes https://www.motorcarsacura.com/acura-service-codes/
Old Oct 25, 2021 | 01:06 PM
dtownfb's Avatar
It looks like it's maintenance minder service codes. Some of the maintenance is based on an algorithm that monitors your driving; others are based on mileage. The one i would be concerned about is the timing chain only because you don't know when it was last done. If it was 105k miles, you are way overdue. If it was 210k miles, you may have a little time.
Old Oct 25, 2021 | 02:40 PM
Alex Medeiros's Avatar
alexmed2002
Ditto. That's something that I wouldn't take a chance on.
Old Oct 25, 2021 | 05:37 PM
altair47's Avatar
ahh, this is how many services. Incredible)
Old Oct 26, 2021 | 05:11 AM
Kelsen's Avatar
I cannot help but ask what this might mean in English. Inquiring minds want to know!
RFT!!!
Dave Kelsen
It's true that Smokey the Bear deserves praise for his campaign against forest fires, but nobody ever mentions the boy scouts he kills for their hats.
Old Oct 26, 2021 | 06:19 AM
altair47's Avatar
RFT!!!
Dave Kelsen
This is in the sense that I, with my 170k miles, have never seen 5 services at once at the same time and I thought it was some kind of DTC code. I'm very surprised.
I can explain in Russian)
Old Oct 26, 2021 | 08:11 AM
TheSauceBoss's Avatar
So if you're relaying that code correctly, you are doing a full "B" service (engine oil + filter, full inspection) plus:
- Rotating tires
- Replacing your air filters
- Replacing trans fluid
- Doing the 105k service, which includes timing belt, tb tensioner, tb pulleys, replacing your water pump, (during which you should replace your coolant as well), replacing the spark plugs, and a potential valve adjustment (if needed).
- Replacing diff fluid, assuming you're AWD.
In my opinion, it looks more intimidating than it actually is. You're essentially replacing all fluids and filters, in addition to your 105k service (B4 service). To your point, you can probably pass over various things like the air filters and certain fluids depending on their condition. If a fluid or filter looks dirty, you ought to change it. The computer only uses mileage intervals to suggest when things needs to be changed, as others have said. Unfortunately it does not account for the actual state of any fluids or parts.
If you're going to do the 105k service, your coolant typically gets replaced at this time, since the water pump comes off. This would also be an optimal time to replace your thermostat (if its original) since the coolant is drained, but that's up to you.
I'd suggest an Aisin kit for the timing belt and water pump - great success across Acuras on the forums here, can save money over paying a premium for parts at the stealership. The kit includes everything you need for the service, minus spark plugs and coolant. You can get the spark plugs pretty much anywhere, and just make sure to get OEM honda type 2 coolant. https://www.rockauto.com/en/moreinfo...=16088&jsn=876
As for spark plugs, I think NGK laser iridium is the go-to brand across all models, but hopefully someone else can chime in to confirm or deny that claim.
Lastly, unless you're seeing any performance issues, a valve adjustment can be subjective. Further if you're experiencing valve noise, or maybe you want to replace the valve cover gaskets to stop an oil leak, yeah getting one at this time would be beneficial. Otherwise it's up to you. If they've gone that entire 300k+ without being adjusted, I'd maybe look into it just for fun.
Good luck!
Old Oct 28, 2021 | 07:11 PM
wallmike's Avatar
My bad gentlemen. I was not clear. I know what these codes mean. I was just wondering how they appear despite the intervals not being correct. For example, the timing belt to be replaced at 105K or 100K despite my previous replacement was not that many miles ago.
In any case, I got estimate from the always generous and reasonable stealership for the work to be done.
Timing belt $1100
Spark plugs $525
Transmission & transfer case fluid $250
Rear differential fluid $120
Engine & Cabin filters $120 (I always do this myself for $20 parts)
I am going to do the spark plugs myself.
Old Oct 28, 2021 | 07:16 PM
altair47's Avatar
Originally Posted by wallmike
My bad gentlemen. I know what these codes mean. I was just wondering how they appear despite the intervals not being correct. For example, the timing belt to be replaced at 105K or 100K.
Timingbelt $1100
Sparkplugs
Write the VIN number and I will look at the Carfax when the timing belt work is done
Old Oct 28, 2021 | 08:05 PM
Timing belt $1100
Spark plugs $525
If you have the competency to do the spark plugs yourself, I'd venture to say you could also do the trans and diff fluids yourself pretty easily as well. Just my opinion though. All you really need is a funnel and a bucket for the trans fluid, and a fluid pump (like $20 at meijer or walmart) for the diff fluid. Timing belt job sounds a lil pricy.... especially if spark plugs aren't included. Local honda and acura dealerships around me regularly send me coupons for a $650 timing belt job, for reference (parts included, minus water pump). Further, if you provide them the parts, you might be able to talk to them and work out something reasonable.
Old Oct 29, 2021 | 09:57 AM
PintoMusic's Avatar
308,000 miles?? That's barely broken in!!
Old Oct 29, 2021 | 07:12 PM
altair47's Avatar
I do not think so
Old Nov 1, 2021 | 04:05 PM
chilly731's Avatar
308,000 miles...that gives me hope about the longevity of mine! Purely out of curiosity, a bit of a sidetrack here, what gas grade have you been using in your years of owning this car (87, 89, or 91, etc?)?
Old Nov 2, 2021 | 02:16 PM
egads's Avatar
The algorithm does oil life, the rest is based on how many oil changes you have had. That is based on the old 7500 mile oil change interval.
So: at the fourth oil change you get codes for 30,000 mile items (filters, trans fluid)
At the 14th oil change you get stuff for the 105k service.
There is almost never a need to replace Honda coolant before the 105k service. It was even 120k when there was a mileage based service chart in the owner's manual.
But of course you would go ahead and change it with the water pump at 105k. (that said, apparently those that live in the frozen north do change theirs more often)
Using the real thing is important because it does last that long and you don't "flush" out coolant in a Honda engine. Some old fluid will remain. Best to mix the same thing in there.
Brake fluid is every three years regardless of miles.
Old Nov 4, 2021 | 04:33 PM
wallmike's Avatar
87 all the way. I am cheap.
wallmike's Avatar
310,000+ today after a round trip to California.
Old Nov 4, 2021 | 05:05 PM
wallmike's Avatar
I called an Acura dealer while driving through Vegas from Irvine. Asked what they charge for transmission & transfer case fluid service. $360. WTF?! I said dealer in Denver is $110 less. "This is our price" he said. F U Acura dealers. ALL of you.
Old Nov 10, 2021 | 11:39 AM
MinnesotaRDX's Avatar
I think you might have the most miles of any 2G RDX I've heard of. Awesome to see they're capable of 300k+. Have you had to make any repairs outside of typical maintenance?
Old Nov 12, 2021 | 09:58 AM
VisualEchos's Avatar
Andrew
This thread gives me hope. I'm never worried about the vehicle itself, or the engine, but the transmission scares the hell out of me. None of the Japanese companies know how to make a damn decent transmission.
Old Nov 12, 2021 | 02:32 PM
chilly731's Avatar
310,000+ miles and used 87 gas throughout the car's life. This thread needs to be shown to all those "premium vs regular gas" debate threads, to settle the topic once and for all.
Old Nov 13, 2021 | 11:56 PM
egads's Avatar
Change the fluid every 30k at least and every other oil change if you want to be prudent. (Normal 1/3 drain & fill)
Old Nov 14, 2021 | 06:57 AM
altair47's Avatar
I agree, this transmission is also not expensive at all and replacement(7-10hr labor) along with a good used transmission(40-80K milles) will cost about $2K, very very cheap.
Old Nov 16, 2021 | 08:34 AM
Like most things in life - if you take care of it, it will last. I'm not saying that some Honda transmissions aren't inherently flawed, but these forums are a goldmine for finding people who have prolonged the life of said inherently flawed transmissions. Plenty of people pushing 300k, 400k on 2G and 3G TL 5ATs, through both routine and specified maintenance. I think the problem lies in the fact that the majority of owners don't focus too much on trans fluid changes, pressure switch replacement, filter replacement, etc. Some of these transmissions will definitely make you pay for missing fluid changes. (Though the 2G RDX transmission seems to be more robust than most Honda trans) But since you've been part of the forums, I'm sure you're already ahead of the game with what your vehicle needs, and you'll do fine.
Cheap Guy
Jan 9, 2021 04:58 PM
Big See
1/2G MDX (2001-2013)
Mar 22, 2018 03:05 PM
Clairette the CL
2G CL Problems & Fixes
Dec 7, 2016 10:38 PM
Crag
1G RDX Problems & Fixes
Jan 26, 2014 11:25 AM
SilverBullet
Jan 22, 2006 03:45 PM
