2016 RDX Center Console Latch
Old Jan 4, 2025 | 01:37 PM
Anovice's Avatar
The plastic latch broke at the pin, which I understand is fairly common. There seems to be no problem getting a replacement piece, either OEM or after market. The part number is 83417-TX4-AO1.
https://www.acurapartswarehouse.com/...7-tx4-a01.html
https://acura.bernardiparts.com/Acur...7-TX4-A01.aspx
Amazon Amazon
I gather it does not make a difference if I purchase OEM or not.
Here is where I become confused. So far, I can't locate the spring but it must be some place in the car. I think that the part number is 83411-TX4-AO1. When you look at the after market plastic latch in the link above, it shows one spring on the pin (that broke off). However, when you Google that part number, you come up with a "double" spring.
https://www.acurapartswarehouse.com/...1-tx4-a01.html
https://www.curryacuraparts.com/oem-...ng-83411tx4a01
I called two Acura dealers and both said that the spring can't be purchased separately and only with the lid for about $700!
My two questions are:
1. Is the OEM one spring as shown in the above Amazon link with the console latch?
2. Or, is the spring a "double" one as showing AcuraPartsWarehouse link above and the Curry Acura ink?
Thank you!
Old Jan 4, 2025 | 08:42 PM
altair47's Avatar
There should be one single spring. The double spring on yours link the entire armrest lift and does not relate to the latch. Buy on Amazon.
Old Jan 5, 2025 | 05:05 AM
jim's acura's Avatar
I think the spring in your acurapartswarehouse link is on the armrest hinge end, not the latch. You need the latch spring.
I've had the plastic knob break twice. First time I replaced it with a knockoff, second time with OEM.
I didn't lose the spring, fortunately, because I, too, have heard they're not available from Acura. You might want to sweep through your car interior nooks and crannies, under the seats, inside the console, etc. with a magnet or a car vacuum that you can retrieve yours from if it's still in the car and to be found.
I'm sure there's a similar spring available from a spring manufacturer or distributor somewhere, but I don't know the specs. The latch spring is a torsion spring that looks something like this (scroll down): https://www.springsfast.com/products/torsion-springs/
Old Jan 5, 2025 | 05:45 AM
Kelsen's Avatar
I purchased a couple of them when I broke mine some years ago, but I had a devil of a time finding that spring as well. It's there in the car somewhere, unless it wound up in your clothes somehow and got carried out. Good luck!
RFT!!!
Dave Kelsen
Birthdays are good for you: the more you have, the longer you live.
Old Jan 5, 2025 | 06:13 AM
Anovice's Avatar
Thanks for all your responses. I found the spring in the car, so that's no longer an issue.
Is there noticeable difference in quality or fit between the OEM and after market black plastic latch? Amazon is easier because I have Prime, but the OEM part is only a few more dollars.
Old Jan 5, 2025 | 06:21 AM
Kelsen's Avatar
I can't say; I bought the pair I bought from Amazon, and one of them broke not long after I installed it. The other has been fine for 4 years. I would recommend getting a couple from Amazon. It's hard to see how something so simple could be engineered much differently whether OEM or a knockoff. But maybe that's just me.
RFT!!!
Dave Kelsen
"The Government of the United States is not, in any sense, founded on the Christian religion." -- John Adams, The Treaty of Tripoli, 1796
Old Jan 5, 2025 | 09:36 AM
The original part lasted 9 years. The Amazon knockoff replacement lasted about a year. The OEM replacement has lasted for over 2 years. You don't know the quality of the knockoff plastic or engineering tolerances. I go with Acura OEM for almost everything, because I don't like to have to make the same repair twice. Plus, every time it breaks, there's a chance of losing that priceless spring! :-)
Old Jan 5, 2025 | 02:32 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
I always go OEM and our replacement latch is at ~4 years.
Old Jan 26, 2025 | 02:22 PM
rx7bmwmunky's Avatar
7th Gear
I purchased my replacement console latch from Aliexpress for $2.50. It looked exactly like OEM. Have had no issues with quality so far. This is the part name.
OEMASSIVE For Acura RDX 5 Door 2013 2014 2015 2016 2017 2018 Center Console Latch Armrest Storage Box Lock Lid 83417-TX4-A01
Ron_L
3G RDX (2019+)
Oct 27, 2023 12:17 AM
Mo_Green
2G RDX DIY & FAQ
Jun 3, 2023 06:31 PM
Shank009
Nov 15, 2020 05:43 PM
emh2020
2G RDX Problems & Fixes
May 16, 2019 07:45 AM
2007.RDXn
1G RDX DIY & FAQ
Jun 28, 2012 12:59 PM
