Fitment Question
Old Nov 13, 2006 | 07:03 PM
3.2CLS's Avatar
The Case Worker
Fitment Question
I was wondering if the TL A-Spec wheels 18x8 with a +45 offset would fit on my 2001 CL-S. Here's the link if you need more info:
https://acurazine.com/forums/car-parts-sale-361/sold-fs-18-sparkle-silver-spec-wheels-tl-351697/
Anyway, please let me know as I'd like to grab these soon if possible.
Thanks,
Andrew
Old Nov 13, 2006 | 09:33 PM
Stealth CL's Avatar
proffesion...axle breaker
they will fit, but will stick out just a lil bit...and may rub if you drop it
3.2CLS's Avatar
The Case Worker
Do you know if anyone has done it and if so I'd like to see pics
Old Nov 14, 2006 | 07:59 AM
fuzzy02CLS's Avatar
It's not a question of a-spec rims, the rim doesn't matter, what does is they are 18X8 +45 offset. Any 18 rim that is that size will fit the same.
And the answer is if you not dropped they will be fine.
If you are dropped, they may rub. Depends on drop, alignment settings, sag, & car specifics(not all CL's are =)
Old Nov 14, 2006 | 12:55 PM
3.2CLS's Avatar
The Case Worker
I was thinking of just doing some H&R springs for a small drop. I don't really want anything to have the tucked look, I had that on my Mercedes and not really in the mood for that again.
So my question would be then, with these wheels what do you think would be the best suspension set up so there is just under a finger's gap between each wheel?
Old Nov 14, 2006 | 01:12 PM
CL Platano's Avatar
Tristate ViP Crew
They may stick out a bit, I've seen it done on both a 99 TL and 03 TL and on the 99 it sticks out a bit in the front but on the 03 TL its sits fine. In other words its trial and error with these wheels. I think also on the 99 he put 235's on them so try 225/40/18 and you may be ok
Old Nov 14, 2006 | 09:43 PM
Stealth CL's Avatar
i have a finger gap with my 17x8 +45, with 235/45/17 tires....and i rub some. just on hard turns and dips tho...tokico illuminas, with eibach pro-kit springs
Old Nov 15, 2006 | 01:04 PM
3.2CLS's Avatar
The Case Worker
Sounds good, so I should go with 225/40/18? I just want to fit everything right before I buy the wheels. Let me know
Thanks guys
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
