eibach pro kit
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
ok so i was thinking in getting the springs from eibach part number 4041.140. It says its a 2 inch drop in the front and 1.7 drop in the back. Has anyone purchased these springs before? Have you had any issues with rubbing or bottoming out? I currently have stock rims and tires.
Tons of info found by using search...
I'm relatively new too but like all car forums, you can find exactly what you need especially when it comes to the 2G for that matter since a ton of members have owned one for years so suspension threads are loaded with good info if you take time to search or prepare to get flamed on the above question!
Whats up with RDX owners?
Search the suspension forum.
But a quick answer to your question is no, it wont rub with the stock wheels/tires.
Youll be fine with the 235s on the 18s. Thats what Im running.
Yes, many people have those springs, including me.
![](http://farm3.static.flickr.com/2673/4228201975_6b7a956619_b.jpg)
Yea, you need to search. I know its annoying, but everything this is there that you need to know. I researched for a very long time before deciding to go with these.
Well, its fine yes, as long as offsets okay.
Youll be fine.
You'll be fine with 18" wheels and it won't rub. I'm running 20" wheels on mine with a 2" drop all the way around.
![](http://farm3.static.flickr.com/2738/4227386447_f0afe3af3a_b.jpg)
I havent noticed any unusual wear yet, but I have only driven maybe 500 miles since lowering it.
B A N N E D
This is my alignment sheet with Eibach prokit/illuminas. Only thing out of spec. was rear left camber by .2 and thats not worth it to get a camber kit because its toe that eats tires and they got toe within spec
hard to read some of the numbers
![Squint](https://acurazine.com/forums/images/smilies/squint.gif)
but i know 1.5 degress of rear camber is still within spec, but it is still quite a bit on the excessive side (i only have 0.6 rear camber right now and might go to 0.9-1.0 next time), just know that the inside edges are going to wear quite a bit more then the outside edges
but one nice thing about that rear camber is it won't let the car be as tail happy, as some of our cars out there
and yes toe is the most critical angle as far as tire wear goes
B A N N E D
and they won't really be wearing improperly, just a little excessive from the nature of your alignment specs (a little on the aggressive side)
and as far as alignments go, the best camber for even tire edge wear would be absolutly 0 degrees of camber, and 0 degrees of toe; but with those specs the car would not be totally stable, with not much cournering ability (also for toe you kinda gotta compensate for suspension give as you roll along the road [which is why they call for a little toe in on the rear])
How wide are your wheels & what offset are they? What size tires did you go with? I would like to buy some wheels that are 20" x 8.5" and wrap them in 245/30/20 tires...
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
