Camber kits is it necessary?
RecentlyI had my car dropped with eibach springs pro kit 2.0 front 1.7 rear and I've noticed that my tires is wearing down rather quickly on the inside, mainly the front. I remembered the mechanic mentioning something bout CAMBER correction kit. At the time I was too excited bout lowering my CL and pay no attention. So the questions is...What is a Cambers? do I need it? and how much will it cost? is it hard to do? Does anybody has this problem? Any help or suggestion is greatly appreciated and thank you in advance.
smr cl_s
search is your friend. you'll find plenty of info on this.
yes, its necessary when you lower a car, especially if youre already noticing wear. search and you'll find all the info you need.
RIP Dodge Shadow
im runnin just barely negative in the front and around -1.1 in the rear...i havent noticed uneven treadwear that would make me consider buyin a camber kit. im dropped on tein basics pretty low too, not slammed, but prolly around 2 inches. what are ur tire/wheel specs?
i have exact same wheel and tire size and mine are probably good a year with no camber kit and an alignment, might have something to do with your tires treadwear number. My tires are nankang
Photoshop Junkie
I needed one bad.
I definitely needed a camber kit. I kept getting alignments and the car never really drove 100% straight after i got it lowered. Since I got the camber kit last summer, I've had no problems whatsoever!
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
