Trunk Lid Screw Size
Old Sep 30, 2019 | 05:32 PM
KAD's Avatar
KAD
7th Gear
Hi, right now my trunk is just slamming down and I realized it is because my torsion bars are not secured to the roof. Does anyone know the specific screw size for the metal bracket? (pic attached)
Old Oct 1, 2019 | 06:59 AM
That center bracket's weld(s), holding the torsion bar center clip, to the body have separated. I just check the one in my CLS6. You will need to reattach it somehow. Probably with some type of metal screws from the hardware store?
Old Oct 1, 2019 | 01:01 PM
01acls's Avatar
Try a needle nose Visegrip to hold the bracket in place.
Old Feb 12, 2020 | 05:37 PM
@KAD
Hey KAD, if you are still out there, this is how I fixed the problem you mention above. I used four sheet metal screws to secure the bracket that separated from its factory welds. After removing the Navi box & shelf it sits on, First, I removed the bracket from the trunk torsion bars then drilled four holes in the bracket. Second, I held the bracket in the area where it originally was attached, marked and drilled pilot holes for the four sheet metal screws. Third, then screwed the bracket to the area it was formally welded to. It does not look pretty; however, it fixed this PIA problem. Sorry for the crappy pictures, but you'll get the idea. We'll see how long it holds up.
Jsouthern
Mar 9, 2013 06:29 AM
6mtV6
Apr 3, 2005 06:26 PM
TSX 'R' US
Sep 13, 2004 11:00 PM
NagChampa
Jun 2, 2003 02:19 PM
cl-assic
1G CL Photograph Gallery
Nov 23, 2002 02:45 PM
