Right side window regulator
Old Mar 10, 2023 | 03:28 PM
asb32952's Avatar
It was working intermittently, then not at all. I can hear the clicking at the switch. Took off the door panel to get to it and banged it around and it started working again. Then it got locked up again in the up position. I got it out without cutting the cable. What a pain in the ass for the last two bolts. Then I plugged it back in and it works. Question is, does the motor get weak, or do they just go out all at once. The motor was a little warm to the touch. Headed to wm to get some silicone spray for all the tracks. Otherwise I'll just order a new dorman. Did the left side a few months ago, but the pass side is prob only used 10% of the time compaired to the drivers side.
Old Mar 10, 2023 | 03:37 PM
I used to use the spray silicone, until I was told this stuff is better:
It's a little more difficult to apply to the door tracks, being a paste; however, you only do it 'once' and you are done.
Old Mar 10, 2023 | 07:55 PM
asb32952's Avatar
Thanks.
Old Mar 10, 2023 | 07:57 PM
asb32952's Avatar
Prob have it in the concubine brothels for free if you order a double over there. Thanks..
Old Mar 10, 2023 | 09:24 PM
Those '...over there' will have / hold our right flank, against the red savages, until reinforcements arrive.
Old Mar 10, 2023 | 10:57 PM
Thefireball's Avatar
I am dumb
My friend was telling me about this stuff, and let me borrow his tube. Used it to grease the shifter where the rod sticks in. Stuff worked great for that. He told me to try it on my door seals as well, but I forgot.
Definitely recommend this stuff. Got get myself some.
Old Mar 11, 2023 | 05:36 PM
asb32952's Avatar
Didn't want to wait walmart is 2 miles from the house. Will use it on the hinges and garage door.
https://www.walmart.com/ip/WD-40-Spe...sRedirect=true
Aleax
Jan 17, 2020 07:19 PM
jwoods4290
Jul 16, 2016 11:19 AM
matt24
Jan 31, 2011 02:31 PM
subbuzz
Apr 16, 2006 06:57 PM
