Power steering fluid leaks
Old May 15, 2013 | 07:42 PM
kaph1202's Avatar
I'm a new member to this community. I owned a 2001 Acura CL 3.2 last week. I loved the car until 2 days back. Now, I'm having a weird sound whenever I try to turn the steering. I showed it to a mechanic and he said the power steering fluid is leaking and you need a new power steering hose. I remember I read something about the power steering hose being recalled for Acura CL 3.2 I wonder if I can go an acura dealer and ask him to replace it free of cost? I owned this car last week and I'm not sure if the previous owner has already made a change to it. Please help me in this. Can I get the power steering hose free of cost or do I have to buy one?
Old May 17, 2013 | 07:21 PM
aznboi2424's Avatar
Best thing to do is to call the dealer and see if there is such a recall. There's not one, I think.
Old May 17, 2013 | 11:22 PM
BAGII's Avatar
Yeah, I work at the dealer. I know there's not a recall for a power steering hose; only for '04-'08 TL's and TSX's.
Old May 19, 2013 | 01:02 AM
clpassenubye's Avatar
ABP-KBP-CBP & ME
Just hope that a new hose is the only problem.
Old May 19, 2013 | 05:16 PM
BAGII's Avatar
You just gotta put some new fluid in it and find the leak. It's normally not too difficult. P/S pump, rack & pinion, or hoses. The noise you're hearing is pump sucking air when the fluid gets low.
Old May 20, 2013 | 07:51 AM
fuzzy02CLS's Avatar
A hose is under $20 & you can replace it yourself easy. No big deal. However it may be the steering rack. Better hope it's only the hose. I had to replace the rack. It was not cheap.
Old May 28, 2013 | 12:33 PM
likeawp's Avatar
I just fixed this issue as well, it is probably a blown gasket or O-ring inside the power steering pump causing it to leak a little fluid and air (hence you hear the whistling sound). I just bought a rebuilt pump for $90 and replaced it, also flushed the system with new power steering fluid. The squeaking sound is gone and feels like new, can do a full U-turn in complete silence
Old Jun 13, 2013 | 08:45 AM
XxAtTheGatesxX's Avatar
Guitarded
Where did you get a rebuilt pump? My power steering has been leaking for some time.
Old Jun 13, 2013 | 12:51 PM
champ14007's Avatar
Were did buy your pump from. Ive been looking to purchase one but their all going for 200 and up plus core charge.
Old Jun 13, 2013 | 09:15 PM
helloha1's Avatar
Rockauto looks pretty cheap.
Old Jul 10, 2013 | 11:11 PM
mordor110's Avatar
Nick
I got a pump off a car in the junk yard OEM for $20. I've only ever seen a Honda PS pump go bad if it was run dry of fluid. Which I think the prior owner did on my CL as my pump was noisy and had weak pump action for the steering.
OP don't run your car with no PS fluid.
Most likely it's the high pressure hose coming off the pump going down to the rack. In 20 years of owning Honda's this has been the only PS hose I've had fail on them. It's usually under $100 for OEM hose online. About $80 non OEM at Autozone or such places.
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
