Poor Gas Milage
Old Jan 23, 2007 | 07:37 PM
AT7Driver's Avatar
Poor Gas Milage
Very recently I have been getting very poor gas milage. I used to have at least 300 miles by the time i had 1/4 of a tank, now I am lucky to have 200 by the time i have 1/4 of a tank. I can't figure it out, my tires are inflated properly, ive checked my IMRC, do ya think my injectors are dirty? I always use 93 octane. Any suggestions are greatly appreciated!
Old Jan 23, 2007 | 11:55 PM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
What is you driving style? Have you been driving mainly in the city, or highway? Try using a nother gas station next time. Maybe put a can of seafoam or techron in the tank next time you fill up.
Old Jan 29, 2007 | 02:32 PM
Tabasco's Avatar
I too get sucky mileage, 300 gallons per tank, 80 percent hwy @ 80mph. What are some changes that one can do?
Old Jan 29, 2007 | 03:14 PM
Using quality gas is probably the one thing that can increase gas mileage. Using at least 91 octane from Chevron or Shell would probably be my choice. You can also try putting a can of Seafoam or a bottle of Techron with your next fill up. That will help clean out the injectors of carbon build up. Other than that, using 5w20 oil, which is already recommended from the factory. Taking that lead weight off the bottom of your foot will also result in better gas mileage.
Old Jan 29, 2007 | 03:23 PM
Also, check your air filter. A dirty or clogged filter could also reduce gas mileage.
Old Jan 29, 2007 | 04:37 PM
Daprince's Avatar
7th Gear
I purchased an AEM cold air intake which has increased the gas mileage and horsepower. It is a $250 investment, but I believe the improved performance to be worth it!
Old Jan 29, 2007 | 06:41 PM
fsttyms1's Avatar
Also try different brands of fuel. And look for gas stations that dont use 10% ethanol
Old Jan 30, 2007 | 12:02 AM
Check your tire's air pressure as well. Low air pressure could cause a decrease in gas mileage.
Old Jan 30, 2007 | 01:41 PM
RYANGP's Avatar
Not a doctor
I can attest to different brands affecting your mileage
This past tank i tried Citgo instead of Valero and my mileage dropped like a stone
Changing your air filter or using a bottle of seafoam might help as well
Old Feb 7, 2007 | 12:17 AM
Tabasco's Avatar
how much seafoam should i use and should i do it on a full tank? is 1/2 bottom enough on a full tank?
Old Feb 7, 2007 | 01:34 AM
Whole can, half can, doesn't matter, it'll do something no matter what. I'd put the whole can in the tank, unless you've got plans for putting the rest in the crank shaft, and changing out the oil. Should probably be atleast a half a tank of gas when you going to do it.
Old Feb 7, 2007 | 11:19 AM
Tabasco's Avatar
So is 1/2 with oil and 1/2 in tank okay? I see a lot of people add some through the pvc pipe also but i dont want to bother.
1 - Add 1/2 can to oil and 1/2 to gas
2 - Let it set for 10 mins
3 - Start car and drive around block
4 - Change oil within 100 miles.
Is that okay? and is it okay if I skip the pvc part?
Old Feb 7, 2007 | 11:53 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
San Yasin
Sep 29, 2015 10:52 AM
