for panel removal
Old Sep 29, 2012 | 10:17 AM
tom teinert's Avatar
5th Gear
for panel removal
My drivers side for will not open from the inside. Assume that either a clip broke or disconnected. 01 cl type s. Any suggestions or videos
Old Sep 30, 2012 | 06:50 AM
97'CL2.2's Avatar
you need the 2g section but since its a door panel im guessing there are many pressure clips which just pull out and a few screws ull just have to hunt for them...dont force anything and take ur time...im sure the problem will become apparent once the panel is free. good luck!
Old Oct 1, 2012 | 02:05 PM
aznboi2424's Avatar
One screw under the arm rest and another where the interior door handle is. That one is covered with a small plastic cap. Remove interior door handle.
Then start pulling at the sides and bottom and the clips should pop loose. Pull the door panel up and you got it. Watch the harnesses, you'll need to disconnect those before you are able to fully remove the panel.
Jul 16, 2017 07:33 AM
chasingthecool
Mar 9, 2017 05:16 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
dainmezron
Oct 16, 2015 06:56 PM
