P0122 throttle pedal position sensor
My car finally threw a code P0122 throttle pedal position sensor.
I can't find the sensor listed anywhere.
Where is it both on the car & in the Manual?
That is the company I found. It lists TL but not CL. Same motor no? I called and they don't answer between 9-12. I left a message.
I looked at mine now that I know where it is there are no heads on the bolts, that is just mean.
Guess I'll be using my Ingersoll Rand to drill those Fukkerz out.
I have one brand new in the box for sale. Bought it from one of the ebay retailers. Turns out mine was ok.
PM and I'll give you a good price on it. Again, brand spanking new in the box.
I pulled the existing unit, blew air into it and the throttle body side, cleaned the contacts and put it back together all symptoms are gone. I will replace it as soon as the new one comes even if no symptoms occur.
I am pretty relieved as I was concerned first that it was the transmission as among the symptoms was not shifting normally and also that it is possible to fix without dropping almost three hundred on the entire throttle body (shame on you Acura/Honda)
This is the second time my code reader has paid for it's self.
Sorry to post to an old thread but just wanted to document for future searchers that the Dorman 911-753 TP sensor works on the CL (and TL). Replaced and calibrated mine after throwing P0122.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
kixo
Sep 25, 2015 03:07 PM
