One more.... VSA, /!\ , ABS Lights On CL
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Back from my mechanic today, I have these three lights on:
VSA
ABS
This is the work he did:
- Replaced Timing Belts
- Replaced Lower Ball Joints
- Replaced cross threaded bolt on wheel
- Oil Change
- Spark plugs
Something he did in the work above now has my lights on. How do I reset them?
I just got back from the shop and I did not get a computer reading. If the only variables from perfectly working to 3 lights on is the work above... do I need one?
VSA
ABS
- Oil Change
- Spark plugs
Sundance Gold in
Your mechanic busted Abs sensor/sensors. 100%. Just check them using multimeter. Disconnect orange plugs under hood - near suspension towers and check the resistance you should have couple of ohms normally if open = busted.
Do you have a link where I can check the diagrams?
Sundance Gold in
It will trigger all these lights as abs and sensors are part of vsa you get all 3! Do not have links for schematics but you do not need it, check sensor resistnce first
GEezuz.. what do you suggest I do? Where can I get these ABS sensors? Are there aftermarket? I'm psssd right now!
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Sundance Gold in
these aint so expensive about $40 @ acuraoemparts.com. Just locate which one you need as these are diferent for both sides. also sensor wire might have get pinched an cut - go along it down to sensors - check for cut or stretch especially in places where they are clean or greasy - indcation of the area where your mechanic was playing with.
Sundance Gold in
Go back and have that idiot fix it. If he is a mechanic he knows what he had messed up and just playing fool, if he doesnt know ... he is not a mechanic but anothert grease monkey
Well... he replaced the ABS on the right, but the lights are still on because he can't reset the lights? Does that sound logical?
When I went to turn the car on before the fix, while stepping on the brake the VSA flashed as the brake pedal vibrated. It was like as if something was trying to self adjust?
Does anyone know what that means?
Sundance Gold in
Abs gets self tested every time you turn the key, no need to reset anything. Vsa sometimes may stay on and require reset. Is the abs indicator still on? If it is not, try manually resetting vsa, by cycling key on for 1 sec to pos II and 1 sec off - 3 times. ... and it looks like you had abs problem before you went to your mechanic, that "self adjustment" was just abs triggering on because of sensor misread. You would have check abs codes to pinpoint it, I still think it is faulty sensor or stretched wire ... but it might be sth else
Sundance Gold in
Auto technician sounds even worse, whenever I talk to someone that calls himself "auto technician" - guy is playing smart asss , just to make it look more complicated, but actually .... he has been practicing as a mechanic for 6 months ...Today hamburger flipper calls himself a "Professional grill operator" but that is just terminology and political correctness. , sorry I am just to long in bussines. ... and we are talking about ABS here - this is not rocket sicience, ABS was invented over 25 years ago, and it works exactly the same these days - with some cantroller changes and additions like stabilsation systems .
Three months later... I took it to Steve (thanks Nauman) and he ran the computer, got the front left ABS code - we checked it out and saw the ABS sensor cable peeled, naturally it was shorted. So that is what has my dash looking like a freaking Xmas tree.... You guys were right on, thanks...
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
