Oil pan drain plug stripped.help
Old Sep 14, 2011 | 08:09 PM
MS225's Avatar
Where would be a good place to buy a new oil pan?Should i use a gasket or locktite gasket?Or better yet can i fix this?
01 acura CL type s
Old Sep 15, 2011 | 10:39 AM
hotclick56's Avatar
2023 TLX
01 acura CL type s
Try searching your local junk yard dealers at this site:
http://www.mypartshop.com/
Old Sep 15, 2011 | 11:15 AM
StreetKA's Avatar
To be honest depend on the price i would look for new one because this problem is getting pretty common lately and used oil pan should be ok but u know its used and it may get stripped again soon
Old Sep 15, 2011 | 09:30 PM
jlmassey's Avatar
8th Gear
is the PLUG stripped or the threads ? If its just take to a shop they will get it out, If its the threads. get it rethreaded ( im sure they will be able to ) save the money
jlmassey's Avatar
8th Gear
If its just the PLUG*
Old Sep 18, 2011 | 04:50 PM
MS225's Avatar
I think its just the threads and I think i'm going to try to rethread them like mentioned.Wish me luck
Old Sep 18, 2011 | 05:02 PM
civicdrivr's Avatar
Rethread it OFF the engine block so the aluminum shavings dont get stuck in the pain and make their way through the engine.
And no physical gasket, they use Hondabond (its an RTV sealant).
IBankMouse
Jun 13, 2020 12:53 PM
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
LeVeL
Oct 18, 2015 04:19 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
STL TL-S
Sep 23, 2015 08:52 PM
