Oil Leak
Old Jun 4, 2009 | 01:36 PM
Kidwond3r's Avatar
5th Gear
Oil Leak
Hello All I have a small problem I HOPE...here it is I would drive and stop let the car sit smell oil burning maybe 15 min later see an oil spot under the car so the most logical thing i cam up with is the drain plug loose. Nope tighten it still oil spot. Then the next thing was oil pan is leaking. so I dropped the oil pan got the new gasket epoxy ran the car still leaking, the leak looks like its coming from in between the engine and tranny could this be an O ring that is leaking? if so has anyone replaced it before any step or cost would be appreciated.
Old Jun 4, 2009 | 04:31 PM
Woofer's Avatar
Restored this in 1998
Possibly a rear main but would verify it isn't a valve cover gasket first.
Old Jun 4, 2009 | 09:58 PM
camaroracer016's Avatar
between engine and tranny = rear main
Old Jun 4, 2009 | 11:03 PM
Rajca's Avatar
wham bam thank you ma'am
x3 on rear main seal. its an $8 part but u need to take the trans out to replace it, and its easy to replace.
Old Jun 5, 2009 | 10:19 AM
civicdrivr's Avatar
Very easy to replace. Not so easy to get to.
Old Jun 10, 2009 | 02:47 AM
Kidwond3r's Avatar
5th Gear
thanks everyone i have't removed a tranny on an acura before you say its the rear main seal..I am looking for the part and any helpful hints on the removal of the tranny i wold be thankful
Old Jun 10, 2009 | 11:51 AM
civicdrivr's Avatar
Hint #1 - Get a Helms manual.
Old Jun 10, 2009 | 02:26 PM
fsttyms1's Avatar
Rear main. Removal of the trans itself is easy. But its a HEAVY son of a Biotch. half shafts need to be removed, front sub frame member needs to be removed, remove lower inspection cover rotate crank as to remove the bolts that hold the flex plate to tq converter then with floor jack supporting trans (helps to have a trans jack) remove the bolts that hold the trans to the motor (and any and all wiring to trans) and drop out the bottom.
Old Jun 10, 2009 | 07:01 PM
CH46ESeaKnight's Avatar
Oh is that all? Sounds easier than it is! As usual.
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Avenger411
Oct 11, 2015 03:53 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
