Odd Problem
Old May 10, 2009 | 05:53 PM
pits200's Avatar
Odd Problem
Driving yesterday, I put my car in park on a step hill. As I pushed on the brake and attempted to move it out of park, it would not disengage.
I had to use the emergency push button on the side of the shift lever to get it to get out of park. I noticed that when I hit the brake it does not make the "Click" sound which disengages the park lock.
Also, while driving today I needed to use my horn and it didn't work. I tested it by pressing the "panic" button on my key chain and all it did was flash the lights.
I checked the "Horn Relay" fuse and it was fine. I replaced it with the "Light Relay" fuse right next to it and still no luck.
All other electronics work in my car. (I.e, windows, seats, lights, turn signals, everything)
Please I need some help here, any input would be great.
Old May 10, 2009 | 06:15 PM
Rajca's Avatar
wham bam thank you ma'am
ur brake switch might be going bad. cheap part and easy to repair. check the tl side under diy on how to repair it. check your horn connections.
Old May 10, 2009 | 06:22 PM
pits200's Avatar
Thanks for the quick response. I found the problem. the power from the brake light to the spoiler brake light was pulled loose and shorted out blowing the 20A fuse under the hood labeled "STOP"
This thread can be closed.
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Skirmich
Oct 1, 2015 12:59 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
mellsonnj
Sep 24, 2015 04:42 PM
