No A/C! Help!
Old Jun 22, 2012 | 06:55 PM
withoutcomp1's Avatar
No A/C! Help!
So my a/c compressor is turning on and off so i did a pep boys recharge and still the same thing, any ideas? Also when it is on it makes a squeaking squealing sound there's a few thing it could be, sensor, clutch, compressor by how can i figure what it is without guessing?
Old Jun 23, 2012 | 01:26 AM
civicdrivr's Avatar
We need a bit more contect.
The a/c compressor is supposed to "turn on and off". Thats how the clutch on it works. It doesnt run constantly when you have the a/c on.
What are the actual issues with it? We can't help you without guessing either....
Old Jun 23, 2012 | 07:47 AM
i know its supposed to turn on and off obviously but not every 5 seconds to keep cycling on and off
Old Jun 23, 2012 | 01:01 PM
YeuEmMaiMai's Avatar
low pressure = no turn on
high pressure = cycling of compressor rapidly as the high pressure switch cuts in .
reduce charge until compressor does not cycle on and off constantly anymore.
What I would do is evacuate the system with a vaccum pump, verify that it hold's a vaccum for at least 4 hours and then recharge with proper amount of PAG oil and R134a
Old Jun 23, 2012 | 01:10 PM
civicdrivr's Avatar
Is the a/c still blowing cold air? Is this only at idle? When you had the a/c serviced, did they check the pressure, and if so, what was it?
EDIT - What YeuEmMaiMai said. It sounds like theres too much freon in the system.
Biggie_B
May 27, 2025 05:51 PM
jdm_94-07TypeS
Oct 7, 2015 11:14 PM
hashbrown
Sep 29, 2015 12:13 PM
lovic87
Sep 15, 2015 06:07 PM
dlknight
Sep 3, 2015 07:54 PM
