My CL idles weird?
Old Aug 14, 2011 | 04:16 PM
ironsurfer129's Avatar
CL-Pride
My CL idles weird?
My car is 210k miles, did tune up not too long ago.
However sometimes when I have my AC on, the car will idles at very low rpm (below 800) and feels like the engine going to stall. Any input on this problem?
On freeway when I accelerate, whole car will shake. I assume this is because of engine mount?
thanks
Old Aug 14, 2011 | 06:36 PM
StreetKA's Avatar
any check engine lights ? codes ?
Old Aug 14, 2011 | 07:42 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
idle problems are almost always the IACV idle air control valve.
assuming you don't have a vacume leak or air is seeping into the system from somewhere.
Old Aug 14, 2011 | 08:21 PM
StreetKA's Avatar
Originally Posted by cl-s progression 01
idle problems are almost always the iacv idle air control valve.
Assuming you don't have a vacume leak or air is seeping into the system from somewhere.
+1
Old Aug 14, 2011 | 08:40 PM
CL-Pride
So should I clean the iavc or replace it?
Where is the iavc? By the throttle body?
Old Sep 12, 2011 | 10:48 PM
99TLhot's Avatar
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Old Sep 13, 2011 | 10:33 AM
celynka's Avatar
Sundance Gold in
IAC valve is right by/under the intake, @ the drivers side front of the engine. Kinda looking like 2 inch mushroom
Old Feb 11, 2012 | 07:04 AM
dfv3.2CL-S's Avatar
IACV is mostly like the problem if you dont have a vacuum leak or hose disconnected. The piece is mounted on the throttle body.
DerrickW
Nov 15, 2015 05:52 PM
Skirmich
Oct 1, 2015 12:59 PM
kb1rl
Sep 30, 2015 10:17 AM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
prbori
Sep 27, 2015 01:37 AM
