Legend brake calipers
Old Jan 5, 2019 | 09:55 AM
mattcl-s's Avatar
Just wodering if anyone else has doe this upgrade to their CL and has a mushy feeling brake pedel after? I checked for leaks i did not see any i bled the brake system twice hoping that would stiffin up the pedal still feels the same Is this normal with the upgrade or should i bleed the brakes one more time
Old Jan 5, 2019 | 12:37 PM
I 'upgraded' to these many years ago on my CL-S6 to eliminate having to buy front rotors every 8-10K. They did feel 'mushy' as you mentioned above at first. I remember doing a couple more bleeds, total of four, to try and firm it up. It helped a little. Then I decided to just drive with them a while and see how I liked them. After awhile, I did not fixate on the mushy feel as much and the brakes were totally stopping the car when needed. I guess it is an acquired conditioning of sorts, YMMV.
Best thing about them is that I have not bought a new set of rotors in years, though I drive considerably less these days.
Funny thing is if you compare the 95 Legend master cylinder to the 03 CLS one, the 95 Legend is a little larger. Not sure if that has any bearing on the mushy aspect or not.
03CLS
https://www.oemacuraparts.com/v-2003...aster-cylinder
95 Legend
https://www.oemacuraparts.com/v-1995...aster-cylinder
Old Jan 5, 2019 | 12:42 PM
horseshoez's Avatar
Latent car nut
So I'm curious; given how similar the CL is to the TL, is there a relatively easy path to taking the Brembo setup from the 3G TLs and putting them on the CLs?
Old Jan 5, 2019 | 01:17 PM
The thread below discusses it. From a cursory view it looked involved. Also, back in the day, the RL calipers could also be swapped with a caliper adapter kit from Fastbrakes, I believe.
https://acurazine.com/forums/second-generation-cl-discussion-2000-2003-50/diy-tl-s-brembos-2nd-gen-cl-937508/
Old Jan 5, 2019 | 02:52 PM
mattcl-s's Avatar
03CLS
95 Legend
thanks zeta! I will give it another bleed and see how it does when the snow melts. Its good to know that i didnt do somthing wrong
Old Jan 5, 2019 | 05:50 PM
horseshoez's Avatar
Latent car nut
Based on that, it would seem the RL caliper mod would be preferred.
BayRoC
Apr 2, 2012 07:49 PM
MrHeeltoe
Jun 27, 2008 10:13 PM
G22_Powered_YA1
1G CL Tires, Wheels, & Suspension
Jun 21, 2007 08:47 AM
dawifey's90
May 5, 2005 06:52 AM
850EX
Apr 9, 2002 06:07 PM
