I'm back! Engine problem on my cl-s
Old Sep 28, 2009 | 04:22 PM
Tonman23's Avatar
8th Gear
I am now having engine issues with my 01 cl-s. I am getting check engine light and when I had my friend plug it in with his handy machine it said that every cylinder was misfiring. It won't rev past 5000 rpm and it won't drive over 40 miles per hour. I tried unplugging each ignition coil at a time to see if i lost performance when i did and the doesnt seem to be the problem but I'm not sure. I also noticed that all of a sudden my car sounds louder, like a race car. Doesn't drive like it tho!
any ideas?
Old Sep 28, 2009 | 05:55 PM
Jacobpockros's Avatar
How many miles? Sounds like your whole engine might be going out
Old Sep 28, 2009 | 08:15 PM
NSXNEXT's Avatar
Please don't provide any more advice.
I would go and buy one new coil pack and swap one coil pack at a time.
Typically it's one coil pack that is bad and it causes you to go multiple misfires.
So, start with the front left coil pack. Reset the CEL light and then replace the coil pack. Drive around for a little bit and see if it comes back. If it does, try the front middle coil pack and so forth until you figure out which one is bad. On rare occurances, you could have multiple bad coil packs. In that case, buy a second new one and swap two at a time. Just try all the combinations until you figure it out.
Obviously if none of that works, it could be injectors or other issues. Might be time to see a mechanic.
Rajca's Avatar
wham bam thank you ma'am
what was the recent maint that has been done, mileage on plugs? try seafoam
Old Sep 29, 2009 | 01:38 PM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
great advice go to www.car-parts.com and buy a new engine...J/K
Buy 1 or 2 coil packs and start switching them...Same thing happen to me I had P0300 and and misfire code in cylinders 2-4-5 so I just replaced coil pack #2 and it was all fine .. The ctlinders are
123
456
and fire 1-4-2-5-3-6 so I had 425 and replaced the first in line (4) and that fixed everything my car was shaking real bad and could not go over 40 MPH w/o the car feeling like it was gonna shake itself apart!
My bad coil pack had a spring in it and the spring looked burnet all the other coil pack springs looked good and the metal coler where the bad one the spring was melted and black so maybee look in the coils at the springs to see if any look melted.. Maybee it might be the spark prlugs also?
Old Oct 13, 2009 | 07:31 PM
AACLS82's Avatar
IM having the same issues with mine right now too, I think cylinder 1-3-5 are misfiring and also some other fault. I just ordered all new coil packs and hope this addresses the problem. But Ill keep coming back to check and see if it worked for you because Im hoping it does. How many miles on your car cause mine has approx 83k and its a 01 too. I just got the trans replaced under warranty about a year ago too.
Old Oct 13, 2009 | 07:40 PM
fsttyms1's Avatar
Honestly you probably only need 1 could pack. If you follow the instructions above you can determine which one it is and hopefully save yourself a lot of money on just using 1 coilpack.
Old Oct 26, 2009 | 09:56 AM
Tonman23's Avatar
8th Gear
Fixed!! Turns out my cat was bad. I bought a new one off Ebay and had my buddy pop it in. Cl-s running like new!!
Thanks to everyone for the help!
Old Oct 26, 2009 | 10:38 AM
modelite's Avatar
6th Gear
me too !!!!
Ok so I've had my EGR valve cleaned a hundred times and it has always cleared up the same problem your having.....but now my check engine light is back on and my dashboard is lit up like Christmas ..my car won't go above 50 and sounds like a truck lol Driving me nuts. My mechanic can't figure it out and I may have to bring it down to acura and get charged $1000 lol
Old Oct 26, 2009 | 12:17 PM
civicdrivr's Avatar
Just get the RT cat from Excelerate. Its 1/3 the price Acura wants.
Old Oct 4, 2010 | 01:08 PM
keep it rolling's Avatar
Thanks for all the help you offer NSXNEXT
I was going to work on my sons car by replacing any bad coils but after your post I'm not sure i can. is there a way to reset the CEL by myself. I don't want to get stuck.
Old Oct 4, 2010 | 11:40 PM
At this point the Engine is working.
Old Jun 10, 2011 | 07:43 PM
wadeox's Avatar
i has a similar experience when i added a couple of gallons of racing fuel. the car ran great but after i got on it a couple of times it acted up so i hooked up the comp and it said it was misfiring on just about all cylenders. to fix the prob i put in new plugs. lesson learned just because they recommend 93 or higher doesnt mean run racing fuel,lol
Gary Matthews
2G CL Problems & Fixes
Sep 11, 2015 01:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
jordanboi
Sep 5, 2015 01:33 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
