Ignition Problems
Old Jul 31, 2016 | 07:14 PM
OddballKB's Avatar
Ignition Problems
I'm having problems with my car staring/stopping. Whenever I go to start my car it's rough and sometimes it doesn't even want to start. When I turn off the ignition it's also rough. My battery's still new and I just replaced the spark plugs. What could this be???
Old Aug 4, 2016 | 01:05 PM
Humberwho's Avatar
Have you replaced the fuel pump relay? Not sure about the rough idle etc, but if you have had an excessive temperature change the solder joints can give out , then the car will not start at all. Which is what happened to me. Other folks have reported intermittent starting problems . https://acurazine.com/forums/2g-cl-p...roblem-495108/
Old Aug 4, 2016 | 01:19 PM
Throttle body or fuel injectors need cleaning
teh CL's Avatar
Always helps to check your engine grounds
thx1138
Sep 3, 2023 08:58 AM
gavriil
Feb 11, 2022 11:21 AM
Touchdown88
Mar 31, 2016 08:45 AM
510waffles
Mar 16, 2016 11:32 AM
Ryley
Feb 27, 2016 03:47 PM
