i think i need an ecu
Old 06-06-2010, 01:37 PM
salemboy19's Avatar
i just had the engine replaced in my 01 cl-s an the guy who replaced it said i need a new ecu or my check engine light wont go off. he said that the ecu is not letting my vtech come on so it hiccups really bad when i try to accelerate fast an ill have to let off the gas for it to stop. need some help please!
Old 06-07-2010, 06:08 AM
Sundance Gold in
celynka's Avatar
Sounds strange.... first make sure the guy did not stratch/ rip your wire harness while changing your engine
Old 06-07-2010, 01:03 PM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,323 Likes on 4,900 Posts
You replaced it with another J32A2 right? Not an A1? Maybe the VTEC solenoid is bad. Go to Auto Zone and have them read the code. Then let us know what it is.
Old 06-07-2010, 02:35 PM
salemboy19's Avatar
i went to advanced an got a p1259 code
Old 06-07-2010, 02:36 PM
salemboy19's Avatar
an yeah its an a2 it came out of a tl-s
Old 06-07-2010, 08:10 PM
civicdrivr's Avatar
Yup, VTEC system malfunction. Check oil level and oil pressure. Your VTEC solenoid might be bad.
Clear the code, start the car. Keep it at idle. Does the CEL come on? If so, its electrical. Check the connector on the solenoid.
If it only comes on past 4k rpms, its oil related.
Old 06-07-2010, 08:21 PM
salemboy19's Avatar
thanks will do tomorrow an let u know. how much is a new solenoid?
Old 06-07-2010, 08:33 PM
civicdrivr's Avatar
List price is $70. PN 36171-P8E-A01
Its located on the oil filter housing. Make sure the oil pressure switch plugs and VTEC solenoid plugs arent swapped. I dont remember if they switched the plugs for the newer models or if they are the same like the older engines.
TypeS860
09-03-2021 06:42 PM
cycdaniel
12-17-2019 10:58 AM
Skirmich
10-01-2015 12:59 PM
malvothegreat
09-29-2015 12:38 AM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
Quick Reply: i think i need an ecu
