How To Shut Off SRS Light
Supplies Needed: 2 wires OR I would suggest 2 Alligator Clips (Radio Shack).
Steps:
1) In order to find the MES Connector on an Accord or CL, you have to be on your back and looking up at the fuse box. There are two plugs that are both yellow with green wires coming out of them, but the looms around the wires are yellow. The smaller of these two plugs is the MES Connector. They are located above the hood release latch and plugged into the backside of the fuse box. Once again, the smaller (upper) plug is the MES Connector.
2) Clip one alligator clip to one of the prongs and the other alligator clip to the other prong. If you're using 2
strands of wire, you won't be clipping, but twisting or shoving the wire into the respective prongs.
3) Hold the two ends of your wire together, so that they are now connected.
4) Keeping the wires connected, turn the ignition on (Do NOT start your car).
5) The SRS light comes on for about 6 seconds and then goes off. Quickly
disconnect the two wires.
6) The SRS light will come on again. Quickly reconnect your wires.
7) The SRS light goes off. Disconnect your wire connection.
8) If you did this correctly, the SRS will blink twice.
9) Turn the ignition off and wait 10 seconds.
10) Turn the ignition on, thus starting your car, and hopefully the SRS light will now be off.
11) Turn your car off, assuming the above instructions worked and your SRS light is off. If not, either retry the
instructions and/or verify that nothing else is wrong.
11) Remove your wires, do not cross them at all or let them touch. Replug the yellow/green connector back into
the "dummy harness".
Problems?
- You only have a 4 second window to connect/disconnect the wires. Example: when the SRS light comes on in
Step 6, you have 4 seconds to reconnect the wires.
- Make sure you have the right connector and that a module or some other part of the SRS system is not
malfunctioning.
- It took me 2 tries to get it right. The main thing to remember is that the wires need to be connected when the
light is on, disconnected when the light is off.
- You can E-Mail me if you still need help:
Email - mjhaughey@yahoo.com
Steps:
Problems?
malfunctioning.
tommystyle86 (10-13-2011)
And Voila, you have no air bags if you get into an accident....
Please no one follow this for long term fixes. If you try doing this to sell a car and the driver who purchases the car with the notion that the air bags are functional, you may be held liable if an accident occurs and no air bags deploy.
Stupid Stupid if you don't get your air bag fixed, i know its a lame part with the SRS, but its needed.
666 Speed
1 Post
^So its OK for honda to do this but not ok for you to do it?
Asked a Honda tech not to long ago how he went about "fixing" my SRS light.
He told me the same procedure. And OMG, the light came back on for the same thing less than a week later. turned out it was the OPDS (i might have the acronym wrong) computer and they "cleared" the code to see if it was actually what they thought...
01 Type-S, Sexy Silver
Acura dealer wanted $100 bucks to "diagnose" the problem... my battery was weak and it caused the SRS light to come on (yeah, go figure). Thx to azine, it wasn't too hard to figure out myself. The reset procedure works if there isn't anything wrong with the SRS system. If there's a fault, the light will come back on within a couple of days.
yup, this is a great post to reset your light to test if you there is anything wrong. i reset it and the light came back on as soon as i put it into drive. now i'm off to figure out what it could be. chances are it's either a sensor or the seatbelt system, as i don't see how an air bag could go 'bad'. i would never think to sell a car with a faulty airbag system. my car sat for a couple months and i replaced the battery and main relay, an acura tech told me the light sometimes comes on and to try to reset it. thanks for implying that i'm unethical, but you have no clue what your talking about.
Sorry, I forgot you have dubbed yourself the airbag guru. You do realize Clean that there are other people posting on this thread and its not all about you.
It was a general question and I never said the actual airbag would go "Bad". Its obvious that these cars have problems with the OPDS sensors and if this is the issue and the SRS light comes on, your airbags will not deploy.
So maybe if you reread my original post you will not be so testy.
Because maybe you aren't unethical, but after seeing people trying to put mismatched tires, bald tires, bad brakes and other retarded things to their car, Im pretty sure someone resetting their SRS light over and over isn't out of the realm or reality.
So maybe its you who have no idea what you are talking about.
this post has been up since august and i reply... and in my signature it says my car is for sale, and your reply mentions if you are doing this to sell a car... what am i to infer?
either way i still think is a good post. it's easy for lights to come on unnecessarily so this is a good way to test if it's a real problem or not. as i and someone else mentioned, if there is a real problem, the light will essentially come back on right away.
Fair enough, but I know your car ability from previous posts and I know you wouldn't short cut on something such as this.
It was a coincidence that my statement coincided with you selling your car, but it does not pertain to you in general. It was a generic comment meant to ward off idiots who think this reset is meant to be used over and over.
Yes its a useful post if this is a one time reset, I can agree with that.
Sundance Gold in
I reset my SRS light about a month ago using only a paper clip. The SRS light came on after I replaced my driver side window motor. It turned out to be simple to reset.
I am sorry to say that, but what you are saying is a BS. This procedure is for a module reset, not SRS bypass or some hack to trick computer not to detect borken SRS components. Its 100% legal Honda/Acura service procedure and we do it so frequently because of bad design of OPDS system which actually had been recalled and trust me nobody will ever get liable for doing that except maybe Honda for manufacturing crap!
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
