How to remove the rotor screws?
Old Dec 28, 2009 | 01:46 AM
hermtm2's Avatar
Hi.
It took me 3 hours to remove the front-left rotor screw, so I really want to know how to take them out. What I've done were drilling and torching the screws but nothing work. Please help me.
Old Dec 28, 2009 | 03:29 AM
blackasscls's Avatar
Impact driver. Its a screwdriver you hit with a hammer and as you hit it twists and the force of the hammer makes sure it stays in.
If you already drilled em outthen idk what to tell you, drill em out some more I guess but you woulda saved a lot of time with the above mentioned method.
Old Jan 11, 2010 | 01:59 PM
AcuraGman's Avatar
Yeah, once you put the drill to them, you messed up the screws. The only alternative is to continue to drill them through. When you completely destroy the screws, you have to take the remaining pieces out. Hopefully you didn't destroy the threads. If you did, just re-tap them with a tap set.
Old Jan 11, 2010 | 02:13 PM
Nersh7's Avatar
I Drive Like A Dick 8≈
probably something you wanted to look up before doing
Old Jan 12, 2010 | 09:16 PM
hermtm2's Avatar
It took me 2 hours to remove the screws.
Basically there were two methods. The first one was the impact driver with PB-blaster. I drilled the screw with a titanium drill when the driver failed.
Here is another question.
Do I have breed the brake fluid when the pads were replaced?
I replaced the pads but I did not breed the fluid at all.
Old Jan 13, 2010 | 11:31 AM
NSXNEXT's Avatar
Do you have to?
Should you?
I didn't (was in a rush) and the first time I stepped on the brake it went right to the floor. Had to pump it a few times to get it back to normal.
Old Jan 14, 2010 | 06:34 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
get a drill..put it on tq mode (the slow mode) put it in reverse... make sure u got the right it or u'll strip it for sure...
push on drill, press reverse and ur done..
attempting that by hand is a joke really, i cannot see them coming out that way
Old Jan 14, 2010 | 07:53 PM
TarzanCLS's Avatar
you cant use a regular bit to go in reverse on a drill to get the screw out, the 2 edges dont bite that way. you need an extractor bit and/or T-handle which can also be done by hand. if you cant see it happening thats because you never tried correctly. next time use the impact screwdriver and a BFH like some sated above. shouldnt take more than 5 good hits w/ the hammer and some PB!
Old Jan 15, 2010 | 07:46 PM
victorvu's Avatar
^^ i agree the impact screw driver is the best thing invented i have 2 of them. i suggest if your screws are rusted use some liquid wrench let it sit for 5-10 mins add some more and knock it with the impact screw driver it should pop right out.
Old Jan 15, 2010 | 08:55 PM
CLPimpin114's Avatar
Tokin up in
I did this two month ago. Was 1 hour into job Got pissed so i got me a impact screw driver, made life easier on me lol. Best $30 ive spent.
lanechanger
Oct 13, 2015 10:56 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
StevieB1503
ILX
Oct 8, 2015 04:52 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
Brandle34
Sep 23, 2015 07:20 PM
