How to install CorSport Bushing ?
Old Mar 9, 2011 | 10:31 PM
ivan06106's Avatar
wazup guys, i have a set of CorSport that im trying to install, has anyone installed them on their Cl, an can some one direct me to the right direction ? its an 03 cl s m/t
Old Mar 9, 2011 | 10:42 PM
friesm2000's Avatar
B A N N E D
are you having issues removing the actual bushings?
cauase a screw driver works wonders with popping them out
Old Mar 9, 2011 | 10:45 PM
ivan06106's Avatar
i havent done anything yet...probably on friday i be doing that an installing my pedals but was wondering how hard its to replace the bushings
Old Mar 9, 2011 | 10:49 PM
friesm2000's Avatar
B A N N E D
can you pull the intake out without help? if so you probably won't have too many issues doing them
Old Mar 9, 2011 | 10:54 PM
ivan06106's Avatar
this is what i bought CorSport Aluminum Performance Shifter Cable Bushings
Old Mar 11, 2011 | 07:08 AM
joyfil2001's Avatar
It is very easy to do if you are at all mechanically inclined.
1. Remove stock intake
2. Spray bushings with lubricant for easier removal
3. Remove cotter pins on stock bushings
4. Pull shift cables up and off linkage
5. Push or pry old bushings out with screwdriver
6. Install new bushings
7. Shift hard
Old Mar 11, 2011 | 12:40 PM
ivan06106's Avatar
ok thanks
Old Mar 11, 2011 | 12:57 PM
SlickShiftNall6's Avatar
Quarantuning
When pulling up the cables like mentioned in step 4 above, make sure you take the 2 metal clips off. This will release the tension on the cables. They are just above the bushings towards the firewall. Follow the cables up from the bushings and you can't miss them.
Someone could please post up the parts diagram so we can see, please.
Make sure you do this or you could damage the shift cables!
TxRzrBk
Sep 17, 2015 01:07 PM
milehightypes
Sep 10, 2015 12:07 PM
gqdabien
Sep 8, 2015 11:41 PM
