How to install CorSport Bushing ?
wazup guys, i have a set of CorSport that im trying to install, has anyone installed them on their Cl, an can some one direct me to the right direction ? its an 03 cl s m/t
It is very easy to do if you are at all mechanically inclined.
1. Remove stock intake
2. Spray bushings with lubricant for easier removal
3. Remove cotter pins on stock bushings
4. Pull shift cables up and off linkage
5. Push or pry old bushings out with screwdriver
6. Install new bushings
7. Shift hard
7. Shift hard
Quarantuning
When pulling up the cables like mentioned in step 4 above, make sure you take the 2 metal clips off. This will release the tension on the cables. They are just above the bushings towards the firewall. Follow the cables up from the bushings and you can't miss them.
Someone could please post up the parts diagram so we can see, please.![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
Make sure you do this or you could damage the shift cables!
