heater went out
There are 3 things you need to check: linkage for heater valve, heater valve, servo motor. Heater valve is located in engine compartment, between firewal and the engine, you should see 2 hoses going through firewall an linkage wire close to it - attached to valve. Have somebody look at it and turn temperature knob back an forth - with egnition key on. Valve should move, if it doesnt it might be :disconnected linkage, servo motor (under passenger left side heater assembly) or electronics itself. If the valve moves and no heat it might be as simple as clip holding the linkage - valves are unlikely to break. You can open it manualy to verify that heater is not clogged and valve works - just take down the linkage and turn it!
My car isn't blowing hot air and would like to see why before i have a mechanic look at it.
thanks
Diagrams are also available at estore.honda.com
it ended up being a faulty thermostat....pretty simple fix
Biggie_B
02-26-2017 11:14 AM
