Gas for 03 CL type s
Old Nov 20, 2009 | 12:26 PM
bro03cl6sp's Avatar
Wink Gas for 03 CL type s
Anyone know or have any experience with mixing the gas...eg say if you mix an 89 with a 93 octane... result 91.? I also can get non ethanol gas...can you use an 89 vs a 91 if no ethanol? Tks!
Old Nov 20, 2009 | 03:51 PM
friesm2000's Avatar
B A N N E D
always use 91 or higher in your car unless it is an emergency/or out in the boonies and it is not availabe
also 91+ with or without ethanol, doesn't matter
and you will proably see better fuel mileage (and power)with no ethanol in the gas , so i would go for that one
ethanol is cheaper for the oil companys to produce then striaght gas which is partly the reason they like it so much
and as far as mixing you should get 91 when mixing 89 and 93 together if done in a perfect 50/50 ratio
Old Nov 20, 2009 | 05:29 PM
bro03cl6sp's Avatar
Tks, I think I'll try the 93 octane with ethanol mixed with an 89 with no ethanol and check the mileage and performance..
Old Nov 20, 2009 | 05:44 PM
friesm2000's Avatar
B A N N E D
might be a pain in the ass to fill it up every time like that to just save a few cents every tankful, but it's your time, and not mine
Old Nov 20, 2009 | 08:03 PM
YeuEmMaiMai's Avatar
lower than recommended = power power and fuel economy..
Old Nov 21, 2009 | 09:46 AM
Bursaliozer's Avatar
been using 89 all summer with no problem. Got 93 few times and ended up getting lower mpg than 89. I use fuel injection cleaner every 3-4 tanks.
Old Nov 21, 2009 | 01:43 PM
RendanCLS's Avatar
I always use 93 without a dout, I like to think it is way better for the engine and that I get better power.
Old Dec 9, 2009 | 08:33 AM
rudeboyride's Avatar
hey if u have a CLS use 91 and up. reason being is that the cls has hotter pistons meaning higher compression. and also has high lift cams in comparison to the regular cl motor. 89 octane can cause detonation if u have enough carbon build up in the cylinders. remember 93 is harder to burn than 89. 89 has a better chance of being lit by a glowing piece of carbon deposit in the cylinder that 93. Detonation is bad!!!!!!!!!!!!. don't take the chance.
OculiAquilae
Nov 19, 2018 02:24 PM
sockr1
Oct 1, 2015 01:31 AM
Ny1718
Sep 11, 2015 09:21 AM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
