Fog Light
Fog Light
Hey, i'm new to Acurazine and was wondering if someone can help me out with my fog light problem. i just bought the car and it is awesome, minor work being put into it next weekend (tint, debadge,alarm,navi,sub). However the problem i have is that the stock fogs are so weak and yellow. What can i do? i would like to have stong white light. i will post pics next week after the work.
I have a 2003 CL Type S 6 speed and would like to do the same. Model 2003 did not have the running lights so I plan on installing them soon and I agree, a 5 watt bulb is not much light. Have you found or heard of any ideas? Do you have some pics?
Driving lights install on 03 cl-s
Do a search, there is a lot of info out there on how to do it. Be careful though, one idiot said to tap the wire to power the lights from the headlight. This will cause the balast to blow. I did the install myself because I am familiar with 12v. Use a relay to power the driving lights. Tap the wire that gets power when you turn on the headlights to activate only the relay. Power the relay and the driving lights with a wire directly from the battery. It is a very simple install. Do your research, but wire it properly and use relays and inline fuses. If you want precise detailed instructions on how I did mine, email me directly. I would be happy to inform you.
Chuco,
I would like some assistants on wiring the driving lights. I have purchased the L and R lights, both sockets and I plan on purchasing the TL fog light switch. Wiring diagram would be great, what type of relay switch, what size of in line fuse and the brand name/part number of the light bulb.
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
